BlankThis
It's -20C and colder here for the last 2 days and I've really started to notice my that my Golf struggles to maintain it's temperature.
I know the needle is nowhere near accurate but if I let the engine get to heat while I drive with the dial all the way to cold, once I turn it to heat the gauge will drop with a fan speed higher than 1. At lights the gauge drops and if I leave the car running while sitting for a bit it will go to about half-way to running temp. The heat doesn't blow that how either.
I've heard that this issue is more related to the thermostat rather than the coolant sensor.
Thank you
Thank you
