Well, there have been several 210-220 WHP dyno's with PD130/150 injectors here in the states with our rot gut fuel. 17 hybrids, 20's, and GTB22's have made these levels. I don't know the exact difference between BHP and WHP, but I'd imagine at least 10%, maybe upwards of 15%. Couple that, with the better fuel quality in EU and we're looking at an optimistic 253 bhp. Now, if the vnt25 is pushing serious air (SERIOUS) and there was real good tuning (REAL GOOD), you might get another 10-15 bhp. If all those stars lined up, AND the dyno was a little more optimistic than most, it may (MAY) be possible to almost hit 270 bhpPlease read this thread.
Is this true? I've read on the internet, the injectors are maxed out at 220bhp, yet this guy believes to have 270bhp out of his?
Who's right, and who's wrong here?
It is a GT25 turbo too - not to be sniffed at when tuned correctly. I have nothing but respect from Jabba as they tuned a lot of my early car setups, so I wouldn't have a bad word said against them - just need some 3rd party dyno evidence.
There is now way stock injectors will make that power no matter what you do.Methanol may have a lesser btu on its own than straight diesel fuel but try adding some N20 into the mix before righting it off!!
And as for a trap speed over how much hp someone is running well! most fwd cars which have close to 300hp have big problems in putting down its power and these motors usually have around 300lbs or 350lbs of torque at best , when having 400lbs plus you got big big problems and where the larger turbo being a little slower to max boost is a good thing.
The Zafira's torque peaks at 2800rpm and peak power not that much higher, so how is that different to a diesel?? Not all petrol peak at 7-8k rpm. Don't knock it till you've tried it.For one your talking about petrol motors vs diesels which use there torque in different places my mk3 tdi had around 450lbs and was a real brute to get the power down........12/13sec's which is it? there a world apart when talking about diesels.
I could also mention cars that friends of mine have or tune that run in the "ten of the best" but this is not the place for that sort of talk and most of those cars started out life with a good amount of power oe..........my mk3 golf laughed at 330d's and certain Carrera's........a Zafria VX'xxxx do me a faver
DIESELS MY FRIEND DIESELS!!
Agreed. Dyno's can lie very easy. Dyno's give you a ruff idea/ball park figure. I've seen 1 or 2 cars on 1 dyno and then go to another and 2 days later made totally different power. This has made very unhappy owners after parting with loads of money. Normally the power is down on what they first had on their tuners dyno, which helps them to look good!!My point is If you have the power you will have high terminal speed regardless of the actual 1/4 miles time. Therefore this will provide better evidence if the car is making the power.
Most bigger power diesels power and torque is higher in their rev range FACT.
My friends Vectra DIESEL has run a 12.8 twice at its best but does 13.1 - 13.4 mostly with well over 107mph terminal speed every time.
I guess the 330d's, which aren't that quick standard and Carrera's you say your "MK3 laughed at" where clearly out matched by 450lbft and weight!!
Anyway this is off topic...............................stock injector will not make that power.
A car with stock injectors my friend can definitely make this power , !HOW! well if its got another type of fuel supply of course , its no big deal!!...........stick to gassa's
Please note:Methanol may have a lesser btu on its own than straight diesel fuel but try adding some N20 into the mix before righting it off!!
I know it wasn't i was just making a point , but Claudio-FR made the point even better!Please note:
Car in question is not on N20.
Just WMI.
is it safe to run such high duration?270 bhp are possible with stock nozzles, also a friend of mine with an ibiza cupra tdi (BUK) has about 265-270 bhp with my repro. Specs are:
-dbilas dynamics camshaft
-turbo 2260V
-cda airbox
-exaust line 2,5" no kat
-gasoil and oil cooler
-stock nozzles
Duration is very high 44 degree and 1 degree of injection advance!
Performance is similar to mine 1/4 mile in 13.7 sec at 173km/h.
For me over 250 bhp is better put in larger nozzle to reduce duration.
x2 that's my understanding as well.My point is If you have the power you will have high terminal speed regardless of the actual 1/4 miles time. Therefore this will provide better evidence if the car is making the power.
Yeah, wow @44 degrees. Seems a bit excessive off the top of my head?is it safe to run such high duration?
