Anyone had any experience with a Midwest Tubonand Performance VNT17
jmodge
Greenville, MI
2001 alh Jetta, RC2 w/.205's 5speed daily summer commuter and 2000 alh Jetta 5spd swap, 2" lift, hitch, stage 3 TDtuning w/.216's winter cruiser, 1996 Tacoma ALh
When you have your graph up make sure the boxes at the bottom are checked for n75, along with boost actual and specified. Can you get it overboost on WOT runs through the gears?
jmodge
Greenville, MI
Also, if you can’t find the n75 function on your graph, make sure you are in group 11 not group 10, works that way on alh’s anyway
grover32
Idaho
06 Jetta TDI
Hey, about 6 months ago I purchased a PD140 Turbo through tdiupgrades.com and had some major boost lag as well. I did my own installation and found that when my oil line was tightened down it rested on the VNT actuator not allowing it to open. My problem was simple so maybe check that just in case. Turbo has performed amazing since.
