damac
i am swapping this setup into mk2 golf and blindly bought darkside return hose kit where you can cut hose to length with a barb fitting for new style alh block fitting. i could not bend the hose after clocking turbo oil drain port straight down.
i tried a generic an turbo kit from ebay and there is no room for the fittings and to make a small hose run and bend it. i also tried an an to barb adapter with the kits more flexible hose and still not enough.
i may have been able to squeeze it together if the block fitting didn't come out so far and the barb came right off the plate that mounts to turbo. i have been scouring ebay and buying parts blindly but its simply too tight.
so i thought i would ask here about others that may have had to change turbo drain lines for other turbos. i had the old alh turbo drain flexible line and i couldn't bend it to make it fit.
i noticed that hose sure wasnt straight.
so im not sure what i can do here. is there an oil pan with fitting that may exist and stay above the oil level like the turbo needs? there is no oil line restrictor on feed size for my turbo so i figure i want a big drain.
im also worried about the angles. if i magically can find small fittings with a barb coming off each side, probably need each to be 45 degrees and go to stock block location im not sure if that is ok either? seems like an immediate bend on the drain is the same thing as clocking the turbo port at too extreme and angle so i would be better with a straight fitting and gradully bend the hose to the blocks 45 degree fitting. im not even sure if we are talking about a run of 6" of hose at this point.
