maxedtdi
Yea but just a little confused by build date of pump or car...Does this help?
Bill
Bill
That is a good point. When VW said they made a fuel pump revision in a particular month, I would assume/guess that they mean to the pump itself and by transfer to the Golf. The reason I guess this way is that changes will come first (relative to the car build date) to the Golf before the come to the Jetta, because Jettas are presumably built from pre-bundled CKDs ("complete knockdown kits" or something like that) which are shipped over from Germany for assembly, whereas the Golf is built in Germany and gets its parts very quickly. When you compare pump build date to car build date, you will see that Golf's typically get pumps made same month as the car, whereas Jettas get pumps made about 3 months before the car, which is likely the shipping cycle from Germany to Mexico. Lately I have been taking cell phone pics of fuel pumps on each TDI I see, which is how I came to this rather personal conclusion. It is non-scientific and definitely invalid sample!Yea but just a little confused by build date of pump or car...
We need to learn more about the passat cr system.......... Anybody got some more details on the passat system?
Just as a clarification, Jettas are not built from CKD kits. Certain parts - notably engines - are shipped as complete assemblies from Germany, but all the sheet metal is coming from local stamping plants, some from VW's own on-site stamping plant, others from suppliers, and a good many parts are sourced locally to the assembly plant.That is a good point. When VW said they made a fuel pump revision in a particular month, I would assume/guess that they mean to the pump itself and by transfer to the Golf. The reason I guess this way is that changes will come first (relative to the car build date) to the Golf before the come to the Jetta, because Jettas are presumably built from pre-bundled CKDs ("complete knockdown kits" or something like that) which are shipped over from Germany for assembly, whereas the Golf is built in Germany and gets its parts very quickly. ...
Also, to be accurate, the knockdown kits coming out of Germany are probably not technically "C"KDs, because some of the parts are coming in from other parts of the world to Mexico or being made in Mexico. I just don't know what the term for a partial KD is. PKD?
Thanks!This is a very long thread, so the following information my have already been provided. Also, the first link references the second.
Save a copy of the pdf because the site will not keep them there for ever.
2012 Passat TDI service training manual
http://152.66.93.29/audi/download/vw/passat/2012%20passat.pdf
http://152.66.93.29/audi/download/vw/Engine/TDI/3L TDI.pdf
Thanks for these. Has anyone posted this for the current jetta/jsw/golf engines? Just curious to compare some of the details.This is a very long thread, so the following information my have already been provided. Also, the first link references the second.
http://152.66.93.29/audi/download/vw/passat/2012 passat.pdf
http://152.66.93.29/audi/download/vw/Engine/2.0L common rail TDI.pdfThanks for these. Has anyone posted this for the current jetta/jsw/golf engines? Just curious to compare some of the details.
This is such a cool automatic hypermiling technique... I wonder if VW stayed at a Holiday in last night while browsing tdiclub...VW Self Study Passat said:The 6-speed dual clutch transmission 02E in the 2012 Passat has a freewheel function. The purpose of the freewheel function is to isolate the engine from the gearbox in overrun, opening the dual clutch. The engine turns at idling speed and the vehicle coasts without any engine braking effect. This freewheel function promotes fuel savings.
The freewheel function is only possible with the selector lever in the "D" position. If the selector lever is in the "S" position or in the tiptronic gate, or if the driver presses the brake, the freewheel function does not operate. The feature reactivates when the engine is placed under load again
... and they would be absolutely correct, if they were going down a hill that maintained their momentum or if they were approaching some point where they would otherwise use their brakes to decelerate.However, there are many on this site that will argue that you get better mileage coasting in gear than coasting in neutral.
Sometimes you get better mileage coasting in gear and sometimes you get better mileage coasting in neutral.However, there are many on this site that will argue that you get better mileage coasting in gear than coasting in neutral.
The document on the 3.0L TDI engine says about the high pressure fuel pump:
• Self-lubricating"
Self-lubricating means that the pump relies on the fluid it is pumping for lubrication.The 3.0 TDI's HPFP is self-lubricating?
A sump filled with oil constantly bathing the cam and and roller piston would be cool if that's what it has.
Sealed sump or recirculated engine oil through the HPFP maybe?
Has enough time gone by with the 2012s to let us return to the possible addition of the new filtering? A lot of posts have gone by and nothing has developed as a better idea.Here are flow schematics to understand the revised system. 3 adapters will need to be machined based on dimensions already provided and the type of hose connectors selected for this system.
Are 2012's considered "fixed"?Once upon a time long ago we used to discuss adding filtering to the TDI CRs. Our real question was would the filter media handle the ~67 psi. Then VW put their filter in the 2012s at ~67 psi and proved the filter would work.
specsalot had spiffed up my old drawing.
The other ideas have been wait on VW and Bosch. The 2012 design change sends return fuel to the tank and not to the filter. Now a filter inspection does not show early metal particles in case a failure starts.
The filtering pressures have been shown to work by VW. I wonder if the post-warranty VWs are prime for the extra filter. If we would encourage ourselves we might get this done.
eddif
I doubt the 2012's are fixed. My purpose of bringing up the 2012's is to show that filters with ~67 psi have not destroyed the fuel system.Are 2012's considered "fixed"?
I would call in the insurance company now. They might have an interest in the diagnosis, before the evidence disappears.Metal fines are caused by the pump chewing its internals apart. Their presence does not mean the fuel started the failure process by being otherwise contaminated or sub-par. The fuel may, in fact, be ok. Metal fines come from the pump failure, they did not cause the pump failure.
Hold firm, be polite, but insist that it be covered unless they prove the fuel is the cause. In that case, contact your ins co.
