More info...hope this provides enough
Thanks Corsair...you are right I did not provide enough info in this post...I started a thread earlier, but not sure I worded it correctly did not get much feedback so maybe this will be better.
First off, I appreciate any and all help...tdiclub is where I turn to when I have issues and have had nothing but good luck...so many people taking their time to help!
I have lost all pulling power...with it floored it will barely move...first thought was the MAF unplugged it and it runs a little better...good enough to go get the codes pulled...the codes below are with the MAF unplugged! I purchased a new MAF at Advance Auto...it looked different than the one I had...connected it and it ran much worse so I returned it and bought some MAF Sensor Cleaner...took apart my MAF sprayed it down with cleaner and it seemed better but still lagged very badly...unplugged it again and the car pulled much better but no where near normal. Could it still be a bad MAF. Also need to tell you that the MAF wiring harnesses red clip supports inside of the connector has crumbled into many pieces...could this cause a problem still seems to plug in ok but not sure if the red plastic thing has a specific purpose...also notice the turbo is not coming on...if the MAF is bad does it stop the turbo from working properly?
When I crank the car you cannot tell anything is wrong it sits at idle perfectly...then if you rev the engine it starts a kind of jump/sputtering at around 2000 rpm...like I said it runs better if the MAF is unplugged and much worse with it plugged in and I can tell that the turbo is not engaging either way.
As I said I have ordered new vacuum hose to replace all of it, a new MAF, a new MAF Connector, and a new N75. Wondering if I should also replace the MAP Sensor and actuator but don't know how to check either?
P1619 Manufacturer Control Auxiliary Input Output
P0245 Turbo Sup Wastegate Solenoid A Low
P1441 Manufacturer Control Auxiliary Emissions Control
P0216 Injection Timing Control Circuit Malfunction
P0102 MAF Curcuit Low Input
