cdroadwarrior
Hi Everybody,
I have a 2000 VW Golf GL TDI with approximately 141,000 miles. During the past 10k or 15k miles, I have had a check-engine fault light coming on, and I keep reading the code and it is always as follows: "P0380 Glow Plug/Heater CKT A Malfunction".
During the past 60k miles (since I purchased the car), I have replaced the Glow Plugs twice, and the most recent set only have about 20k miles on them. When I clear the code, it stays away for a few hundred miles (a few thousand miles once), and I have cleared it about 5 or 6 times in total, so there seems to be a consistent underlying cause.
The temperatures have been warm (well above the 40 degree F threshold when, as I understand it, the glow-plugs actually function), so I don't understand why this fault code is occurring.
What are the likely causes of this fault? What is the best way to go about investigating this problem?
Thanks again for your help!
- Brock
- Brock
