I have bought a second hand Seat Ibiza Tdi 90CV of 2001
I have to change the oil and on the manual it says that I need to use VW 505 00 or API CF but it also says that this does not apply engines with a pump injector system which in that case i have to use VW 505 01 otherwise engine damage can occur.
The oil shop next door suggested Morris Multivis Semi synthetic 5W30 API CF.
The problem is that both the shop and I don't know what pump injector system is. So he said that I better check. Funilly enough the Seat agent is not available for a week and I need a quick reply because the service is overdue.
Temperatures here in Malta vary from a low of 6 degrees celcius to a high of 40.
I would appreciate a quick reply.
Thanks in advance
Neville
santnev@yahoo.com
Thanks in advance
Neville
santnev@yahoo.com
