Non-heated to heated how hard is it
phawkins224
Forest, Va
2003 Jetta
I have 03 Jetta Tdi torn leather heated seats....found a set thats in good shpe but not heated....how hard is to make them heated........
kbaisley
Midwest
2006 Jetta TDI 5spd
Seats
From what I remember, the heater elements are sewn to the upholstery. I dont remember if its a light tack to the upholstery that can easily be removed or not. If they are removable, easy swap to convert them over.
UhOh
PNW
Yea, as kbaisley says, the elements/pads are integral to the seat covers. If it were me (I've kind of been down this path) I'd hold out for seats that are heated (keeping in mind that you you probably will need to do some repair work).
At least you don't have to do a wire harness retrofit (I'll be doing a second car before Fall sets in).
CoolAirVw
Kansas City Missouri
Jetta
Any upholstery shop can cut the heaters out of your current seats and sew them into the new.
Here at our shop, we are not upholstery guys, but we' have been swapping upholstery from seat to seat. (for instance when we have power seats with nice upholstery and need them in a car that isn't equipped for power seats, so we swap them onto manual seat frames. Its a lot of work but entirely do able by a DIYer. Meaning you could do most of the removal and reinstallation, and drop it off at upholstery shop for them to sew it in.
If you attempt this start on passenger seat with bad upholstery, so if you jack it up who cares, then cut the heaters out, then take apart the other seat Use the airbags from original car or at least make sure you match part numbers on the airbag because it there are year differences that will not work.
Sewing the heater in yourself?
Most upholstery shops us a "walking foot" type sewing machine to make evenly spaced stitching for when its view able. Since sewing the heater in is happening inside the seat and not view able you might be able to get by by sewing it in by hand. Might or might not be able to use a "common" sewing machine to sew in the heaters. I actually think you could because its not view able and evenly spaced "pretty" stitching isn't critical.
