TDICADDGUY said:
Thanks, I saw that before, tried it this morning,. wasnt successful, MoGolf came to my Rescue with the special tool for releasing the booster ball from the back side of the pedal...
unbolted the auto pedal from its pivot, loosened the brake booster from the firewall, popped the new 5 speed pedal into position and all is good with the world.
Kgirls bug is now officially a 5 speed. It drove around the block under its own power for the first time since MAY according to her. Car runs WELL! pulls nicely for 170 k miles. has no reverse lights, but everything else is as if it originally was a 5 speed.
now I need to make an order on impex for all of these misc bits... About $175 worth...
02a 301 115 a
Tranny inspection Plug (was missing)
n 911 082 01
Axle bolts (12x) Reused ones that came with the used axles for now...
1j0 711 693 a
boot clamp sleeve (1x) for the 5 speed leather boot to hold it properly..
n908 482 01
(bolt for ring on shifter (2x) luckily she provided 2x shift boxes. 2nd one had this ring, but I had to slot one of the screws and drill out the other one to get it apart and on the box I installed.
1j0 711 202 p
shifter relay lever with guide piece. converts (melted) ball shifter ends to pin style (late style) to match the Audi TT short Shift Boraparts sent.
02k 945 415 g
reverse switch. To replace the melted one on the tranny
068 103 645 m
tin cover. Small inspection cover on back side of trans. Large one was in the parts.
n 010 208 5
bolt for tin cover 1x .
06a 103 171 a
rear main seal. to replace the one I had to use when I pulled the flex plate off.
1j0 973 702
reverse switch connector. to wire up the new reverse switch on the tranny since the auto doesn't have this connector.
fun fun. its a lot of work, I applaud the guys who do a bunch of these.
Could not have done it without Mogolf, and without Compu_85, my resident (well 3.5 hours away) Wiring expert.
now to drive the car for a week or two to break in the new clutch. Look for the beetle to make it to Whitbreads GTG if some of these parts make it in time.
