lektrikman
I recently bought a 2000 Golf TDI with 160K miles on it. It has been maintained by the dealer, runs very well and doesn't use any oil between changes. I have recently gone through it and replaced the timing belt and all rollers and cleaned the intercooler. There was slightly more than 4 oz of oil in the intercooler, which for 160K miles doesn't sound excessive. While I was checking out the turbo I noticed that there is a small amount of radial play in the turbo shaft, but no detectable axial play. The air inlet to the turbo had a small amount of oil in it as well as the hoses leading into and out of the turbo. The turbo spools up fine and the VNT actuator operates freely. My question is: should I be concerned about the small amount of turbo shaft radial movement, or is that acceptable? Is there a reliable source of information about these turbos that I can contact about my concerns? It goes without saying that reliability is a top priority as I occasionally drive long distances and a road side failure is the last thing I need. Any guidance would be appreciated. Thanks-Lektrikman
