Rickstah
OK, couple of weeks ago I went to Sears to buy some Falkens and the guy talked me into buying some Sumitomos...195 14s...so after I get the car I head home, radio blasting, happy in the knowledge my car is now dealing on H-rated rubber
. My wife drives the car for the next few days and complains about tire noise...
..say what??? When I finally drive the car, sure enough, there is some ugly resonance in the rear, follows the speed of the car starting about 15 mph, then levels off to a steady pitch at about 75...dangit, brand new defective tire. I make arrangements to swap another set of tires, different brand on the car, after I put the spare on the right rear and the sound changes quite a bit...bingo I think.
On the way to Sears this morning, I drove across several different types of pavement and the uneasy thought suddenly hit me that the sound didn't vary...what the...oh no, a bearing? But how would bearing noise suddenly spring into existence as soon as new tires are put on??? I shoved it out of my mind until after I get the new Falkens on, then sit and drink my chai, chanting "bearings good...bearings good..." then I take off...a minute later I am chanting " bearings bad...bearings bad...".
Soo, to make a boring story shorter, took it to Larry's and he scoped it out and said " You got a bad bearing there, fella..".
Gonna have both bearings replaced monday on the rear...but how would new tires exacerbate them to the point they suddenly start howling virtually right after the tires are changed? Could the noise have been there for a long time and I just tuned it out as old tire noise from wear?
Oh well, let it be said that Sumitomo Srixons and Falkens, sold by Sears, are good tires snicker. Rock steady at high speed, will perform way past your ability to keep your buttocks in the seat as you try to swerve to see if the bearings make more noise, he he. That's my story, hope you stayed awake. The moral of the story is bearings going out can sound exactly like tire noise...and can possibly be stressed by new tires? (scratching head)
