Abs and tc on passat b5.5 tdi sport lights on major problems
alicavi
Highlands Scotland Inverness
Passat Se TDi 1.9 awx
I guys wondering if you can shed any light on these dreded codes
VCDS-Lite Version: Release 1.2
Friday, 27 October 2017, 11:42:55:0
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,47,55,56,57,58,75,76,77
Address 01: Engine Labels: 038-906-019-AVF.LBL
Controller: 038 906 019 GQ
Component: 1,9l R4 EDC 0000SG 1524
Coding: 00002
Shop #: WSC 00028
VCID: 6CAB47B30F93
WVWZZZ3BZ3P001373 VWZ7Z0B5214240
3 Faults Found:
18263 - Powertrain Data Bus: Software Version Monitoring
P1855 - 35-10 - - - Intermittent
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 35-10 - - - Intermittent
18044 - Powertrain Data Bus: Missing Message from Airbag Controller
P1636 - 35-00 - -
Readiness: N/A
Address 03: ABS Brakes Labels: 4B0-614-517.LBL
Controller: 4B0 614 517 G
Component: ABS/ESP front 1728
Coding: 04255
Shop #: WSC 12345
VCID: 253D7297ACF9
1 Fault Found:
00778 - Steering Angle Sensor (G85)
37-00 - Faulty
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Controller: 1C0 909 605 C
Component: 08 AIRBAG VW61 04 0001
Coding: 12344
Shop #: WSC 00028
VCID: 243B6F93A7C3
8 Faults Found:
65535 - Internal Control Module Memory Error
00-00 - -
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
00588 - Airbag Igniter; Driver Side (N95)
32-10 - Resistance too High - Intermittent
01299 - Diagnostic Interface for Data Bus (J533)
49-10 - No Communications - Intermittent
00589 - Airbag Igniter 1; Passenger Side (N131)
01217 - Side Airbag Igniter; Driver Side (N199)
01218 - Side Airbag Igniter; Passenger Side (N200)
01588 - Igniter for Head-Airbag; Drivers Side (N251)
Address 17: Instruments Labels: 3B0-920-xx5-17.LBL
Controller: 3B0 920 927 A
Component: KOMBI+WEGFAHRSP VDO V08
Coding: 05415
Shop #: WSC 00000
VCID: 23396C8FA2CD
3 Faults Found:
01316 - ABS Control Module
01321 - Control Module for Airbags (J234)
00476 - Control Module for Fuel Pump (J538)
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Controller: 6N0 909 901
Coding: 00006
Shop #: WSC 00028
VCID: F093D3C3A3BB
6 Faults Found:
01320 - Control Module for Climatronic (J255)
00463 - Control Module for Digital Sound Package (J525)
Address 46: Central Conv. Labels: 1C0-959-799.LBL
Controller: 1C0 959 799 B
Component: 6T Komfortgerát HLO 0001
Coding: 00258
Shop #: WSC 00028
VCID: 361FA5DB015F
12 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01333 - Door Control Module; Rear Left (J388)
01134 - Alarm Horn (H12)
01135 - Interior Monitoring Sensors
36-10 - Open Circuit - Intermittent
00928 - Locking Module for Central Locking; Front Driver Side (F220)
27-00 - Implausible Signal
00943 - Heated Exterior Mirror; Driver Side (Z4)
01359 - Internal Central Locking Switch; Passenger Side (E198)
27-10 - Implausible Signal - Intermittent
00944 - Heated Exterior Mirror; Passenger Side (Z5)
53-00 - Supply Voltage Too Low
00934 - Electric Window Motor; Rear Left (V26)
35-00 - -
00930 - Locking Module for Central Locking; Rear Left (F222)
00931 - Locking Module for Central Locking; Rear Right (F223)
End --------------------------------------------------------------------------------------------------
Thank for any help you can give
nord
Southern Tier NY
All turned back to VW. Now a 2017 Hundai Tuscon. Not a single squalk in 10k miles.
Given the chance of so much being wrong, I think perhaps simple might be the answer...
1. Battery
2. Alternator Clutch
3. Alternator
( I'd place a small bet on the battery.)
Good Luck.
alicavi
Brand new battery on it airbag control module has gone it's the abs tc can't get my head around the module told me that it needed coded. So I coded it now it tells me steering Angel sensor is faulty.
Tdijarhead
Lawrenceville PA
2003 TDI Jetta Daughters Car, 2001 TDI Beetle, Wife’s car, 2005 Golf TDI Mine, all 5 spds
Brand new battery means that you had an old one in there a short time ago. When that many codes are present it’s usually because of a low power battery. Record them as you have done and clear them, see what comes back.
I hope you saved the values of whatever coding you changed. After clearing the codes that is probably the one that will come back. My guess is you will need to return it to whatever value it was before you changed it.
alicavi
I bought the car like that the airbag control module had failed due to as you say battrie being flat and the prev owner jump starting it all the time. So I have removed the centre consel of the car to gain access to the airbag control module. The problem I have is with abs and tc also the steering wheel had been changed again by previous owner. The hand brake light flashes abs light lit up as is tc light. I changed only one code on abs as the module was incorrectly coded. I got another abs control module today same model as the one fitted was going to replace it today but don't know if it will make a difference
Tdijarhead
Lawrenceville PA
If the airbag light was on because of the battery. The code probably reads something about power interruption, all you need to do is clear a code like that, it shouldn't come back as long as the battery is now fully charged.
alicavi
I don't think you understand what I am trying to say airbag control module is knackered. So hence the codes it was sent away for reconditioning. The abs is the problem I have no abs or TC code for steering Angel sensor cleared it came straight back also hand brake light beeping and flashing to tell me I have a majour fault with brakes
Tdijarhead
Lawrenceville PA
Ok understood about the airbag.
On the ross-tech website is the procedure for resetting the steering angle sensor, that might be all you need to do to get rid of the abs light. What is TC? Trouble code? Or an anti slip feature?
http://wiki.ross-tech.com/wiki/index.php/VW_Tiguan_(5N)_Brake_Electronics
I selected ROW (rest of world) Passat but I may have the wrong year you may want to double check that. It looks like the Passat and the Tiguan share the same brakes but double check that.
zzdiesel
sask. mostly now Wa.
05 passat tdi Geared BSM and Bewcam 2nd 2005 deleted ,converted and bew cam stage 2 Malone3 tune.
Steering angle sensor faulty. I suspect you need to replace it.
Tdijarhead
Lawrenceville PA
Does your horn function? The steering angle sensor is usually integrated into the clock spring.
imo000
Cambridge
2009 M-B ML320 Diesel & '05 Passat TDI Manual 5-Speed
Did you disconnect the battery before swapping out the clock spring module?
