ienjoysnails
1z tdi in 79 rabbit. i have 12v at the pins on the tdi glowplug harness however the gps don't heat up. i'm not using a gp relay, just a manual push switch. i did ground the plugs in the block and also to the body of the car when i had them out of the block so its not that. is it that one of the wires on the gp harness isn't suppose to be 12v? there is two as seen in the pic below. anyone?
