Where can I find this wiring harness?
BakoTDI
Bakersfield, CA
Jetta, MK7
So as it typically happens, while you're fixing, or trying to fix one thing, something else is noticed. This is what I found today:
I noticed that the coolant glow plug wiring connections have some cracks on them. Does anyone know where to get replacements?? do they even exist?
ToxicDoc
Virginia, US
2001 Jetta, S7, .216
jettawreck
Northern Minnesota-55744
2001 Jetta and 2003 Jetta
And/or since you live where it's a warm climate you could disconnect/unplug them and probably never notice any difference in warm up times unless you do lots of short, cold start trips. The ECU doesn't monitor their operation and won't throw a code for them being inoperative.
GEFP
Southern Alberta Canada
2- 2001 Jettas, 2 - 2002 Jettas (1 for parts) 2003 1.8t Jetta (parts) 2014 Jetta
Ok so slightly off topic but where in the Bentley manual can I find wiring diagrams (2001 Jetta TDI) for the coolant glow plugs. I've looked through several times and no luck so far.
I doing an automatic swap and want to install the coolant glow plugs as I live where it's cold in winter.
AndyBees
Southeast Kentucky
You know, when I did the 02 ALH install in my Vanagon, I combed the wiring harness schematics almost in my sleep! At the moment, I cannot remember seeing anything on the Coolant GPs. I'm sure it is there somewhere ... just don't remember.
I'll take a look tonight! ........ about to leave here and go for a long trail hike!:D
2many diesels
Nor Cal
rabbit pickup 1z swap Audi A4 Quattro ALH. 02 Beetle TDI. 99 Golf TDI. 03 Wagon TDI. 914 Porsche ALH t
I live in northern California. I am running at least six TDI's without coolant glow plugs. In Bakersfield It will never be a problem.
ToxicDoc
Virginia, US
You're welcome. It will be a dirt-cheap fix. 3 ring terminals, 3 pieces of heat shrink tubing, a little liquid tape for wiring, a die to thread the plugs, and 3 pairs of nuts. All done.
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
Wiring Diagram 32/10
GEFP
So in my Bentley manual it's diagram 81/12. I don't know what the difference is between manuals but your post showed me that there was a part of the wiring diagrams that I wasn't looking in. It took a few minutes to find it but I found what I wanted. Thank you for your help
GEFP
So you made me think did I see this correctly so I just went out and checked. In my Bentley manual it's wiring diagram number 81/12 on wiring diagram page number 97-874. I have two different wiring diagrams on that page.
Prairie Chicken
Northern IL
05 Jetta, 04 Jetta
can't remember where I found it, but similar to the post Toxic shared... instead of ring terminals/threading, I splice on 5mm bullet connectors - they slide right on top of the GP. Have done it on 2 cars without issue.
BakoTDI
Bakersfield, CA
Jetta, MK7
and most likely, this option would make it easier to install some heat shrink on it and keep it clean... nice!!
wonneber
Monroe, NY, USA
OK, now I see where the 81/12 is. :)
