Forcefed TDI
When I drive to work I'm on the highway doing about 80mph. Twice this has happened now, that when I turn the cruse control off the car goes into limp mode. Both times it has happened when the car is accelerating. I checked vagcom for codes and nothing. I replace the air filter, fuel filter, and used diesel purge. I also cleaned the battery grounds under the battery box, checked the MAF, and went through all the vaccum lines. Any ideas on what could be causing this to happen? This has never happened before and now it's twice in 3 days. Nothing else is wrong with the car and I'm still averaging 48 mpg. This is in a 2002 Jetta TDI.
