JB Weld Oil pan?
P2B
Toronto & Muskoka, Canada
How would you rate the chances of fixing this with JB Weld from the outside if I wait until it stops dripping?
This happened with a Defender steel plate in place, it appears the rib in the middle of the plate got pushed against the pan just hard enough to create a tiny crack about half an inch long.
Simon
Windex
Cambridge
05 B5V 01E FRF
What's the widest gap along the inch crack?
JB is good as long as the surfaces are clean and free of grease/oil. If you can get the crack nice and clean, then I would think that your chances are good.
ALH pans are cheap and relatively easy to replace - why not just replace it?
BobnOH
not-a-mechanic
central Ohio
New Beetle 2003 manual
1 in 40.
You'd want to take the pan off to clean, then it might hold, 1 in 3 maybe.
1/4" drive ratchet, socket, 6" extension will do it.
jmodge
Greenville, MI
1 in 40.
I would say better odds, but agree with pulling it. Reminds me of the time some dumb a** broke the corner off my trans after 5spd swap, (this person will remain nameless, I hope). It took forever to stop the leaking. I drilled the end of each crack with a small drill and ground a V in the crack until it JUST began to open. Then one small fine layer, followed by 4 or 5, don't remember which. Held up great. I was very meticulious with the prep work.
Looks like you have quite the gap, can you close it any?
Geomorph
Sacramento, CA
2005 Golf and 2002 NB
I would just replace it. It is going to be difficult to clean without taking it off. If you have to take it off, might as well put a new one back on.
sawmilldon
WA
2004 Wagon
I like the look of those hybrid pans with the steel bottom. I think I will go that route for my next rebuild.
P2B
There is no gap, can't even see the crack. It was parked for two days after it happened, didn't loose enough to notice when I got in and drove 200km. Still had almost a quart in it after sitting another 4 days, but this time I noticed the puddle before starting the engine.
Not as cheap and easy as JB Weld if it works. I'm away for a couple of days, it should have stopped dripping by the time I get back.
Simon
Windex
Cambridge
05 B5V 01E FRF
Just clean it really good with brake clean, and scuff the surface with some 80-120 grit. then clean the surface again.
GEFP
Southern Alberta Canada
2- 2001 Jettas, 2 - 2002 Jettas (1 for parts) 2003 1.8t Jetta (parts) 2014 Jetta
Rub a bar of soap into the crack to stop the leaking. Scuff the surrounding area with sand paper to help with JB weld adhesion. Clean it good with brake clean or equivalent. Just straight JB will seal it but if you want extra insurance just cut a piece of tin and JB it over the crack. I use a piece of wood to hold the tin in place till the JB has cured.
2many diesels
Nor Cal
rabbit pickup 1z swap Audi A4 Quattro ALH. 02 Beetle TDI. 99 Golf TDI. 03 Wagon TDI. 914 Porsche ALH t
I bought a mk4 jetta that had a crack in the oil pan. While I was re-configuring the motor for a longitudinal installation I had the oil pan off. Then I noticed the pan had jb weld on the inside as well as the underside...and it still leaked, and I have no idea how it was preped.
Why in the world would someone go the trouble of removing the pan due to a crack and not replace it?
The cost of a motor vs the cost of an oil pan is huge. Personally I wouldnt risk it.
maxmoo
Lakefield, Ontario, Canada
2000 golf, 2001 golf, 2000 beetle, 2003 wagon, 2004 golf, 2004 jetta, all diesels
I would just replace the pan....your engine needs it's oil to survive.
And then....worry less drive more.
ItAintRodKnock
Fraggle Rock, CO
01GolfTDi
if you gotta remove it to properly clean it up and apply the JB Weld, then you may as well just purchase a new pan and the proper sealer and replace the pan itself.
you can find them cheap sometimes at local VW shops(not dealer)
I did it with just Jack Stands and it isnt terribly difficult, but youll need one extension to get to acouple bolts.
Worry less, Drive more. X2
and in this case, its relatively inexpensive.
Nozzleman
About 15 miles from Venus
2002 Ford Ranger ALH
Gas tank sealer putty might work better than the JB Weld. You do not have to clean the surface to get it to stick. I have fixed gas tanks and oil pans using it. Once on a full tank of gasoline with a 1/2" hole while laying under a '56 Ford Panel in Branson MO.
PB_NB
Vancouver, B.C.
1999 New Beetle
Try some ISO alcohol to clean the weld area after sanding it.
It there is a crack, you can span it with a fabric. Just put one coat on, then push the fabric into the first coat. Then apply another coat and let it set up. It will be bullet proof or at least strong enough to keep the oil in the pan!
This is the same method used with other 2 part sealant products.
Let us know if it all works out in the end.
P2B
http://forums.tdiclub.com/showpost.php?p=3003467&postcount=3
I have jb weld on a small crack in my pan. It's held solid for the last 120K miles. But it depends on the crack. Make sure you get the area very clean and let it set up completely before you add oil.
The crack in my pan is so small it took a week for all the oil to drain out. If it works for runonbeer it'll work for me.
I roughed up the area with 80 grit and cleaned it thoroughly with pure alcohol before applying the JB Weld, and will let it cure for 48 hours (allowing extra cure time because they are calling for -10C overnight) before adding oil. We'll see.
Simon
P2B
It took 36 hours with the frost heater on to fully cure the JB Weld, but the repair shows no sign of leaking after two runs up to operating temperature so I'm optimistic it will hold.
I beat the rib in the skid plate flat before putting it back on so it won't do the same thing again.
Simon
hugho
NW wyoming
red 2002 vw Jetta wagon 250K miles, MT
Simon[/easy answer: NO! NO! NO!. Junkyard oil pans are cheap. JB weld(epoxy) fails with moderate heat. Welding with say tig(off the engine!) totally acceptable. JB weld is epoxy with powdered aluminum I think. I use my own epoxy system with powdered copper all the time, I think better. Never use epoxy if heat is an issue.
GEFP
Oh my goodness! Mechanics have used JB Weld to hold Detroit diesel cylinder liners together till new ones can come in on the next plane. That's a way hotter environment that an oil pan. When your mechanicing in the Arctic you do what needs doing to keep stuff going. JB weld would do quite well on that oil pan. But if your going to take off then I would just get it welded.
BobnOH
not-a-mechanic
central Ohio
Well lets hope the epoxy holds up. I would check it once a month (leave skid plate off if you can) for maybe 6 months
P2B
I'd probably need to keep a few oil pans on the shelf if I planned to drive around for 6 months with no skid plate!
I will check for drips before starting the engine for a while, and continue normal practice of checking oil every fillup.
Simon
BobnOH
not-a-mechanic
central Ohio
The epoxy itself won't fail, but it can loose it's seal. Materials change size from heat or cold and at different rates.
I think you're good, just keep an eye on it for a while.
BobnOH
not-a-mechanic
central Ohio
Simon
If you can, high speed urban traffic is the greatest risk. Well just monitor oil level on the stick.
