2002 Golf Manual transmission. I've searched everything I can think of and haven't read anything that describes this issue, hence the post. Read the GP 101 sticky.
With ECT plugged in I get about a 0.5 second until GP light turns off. Will have to crank engine at least 30 seconds with ambient air temp in 60's first thing with stone cold engine. When I unplug ECT, get approximately 15 second of GP light and engine fires almost instantly.
So, replaced ECT with VW OEM from IDParts. Same symptoms.
So, I think, "Probability is small, but new ECT could be bad." Replace with REIN. Same thing.
BTW, I pulled the harness and get battery voltage at each leg when I cycle key with GP light on. All GP's test at about 1.0-1.2 Ohms.
Does this point to a bad timer/relay? Bad wiring?
Besides the computer getting faulty information about engine temp, is there a problem driving it like this?
