So my Car has had the code "P0402 Exhaust Gas Recirculation Flow Excessive Detected" for a few weeks and I haven't done anything for that yet thinking it's just emissions and wouldn't be a big deal.
However last week while driving uphill I felt my car go into Limp mode and when I went to scan it the OBD port wasn't connecting. [Eventually found blown fuse 12 for the DLC power supply]
So today I can scan the car and pull out code "P1556 Charge Pressure Negative Deviation" Which after searching found it could be Clogged intake (doubt that since I recently cleaned it all out), Actuator that's leaking, bad vacuum lines, or a sticky turbo.
My question is can the P0402 EGR code be causing the P1556 Code? And if it is can I buy a tune that deletes the EGR with a racepipe and use this as a Cure? Any and all advice welcomed. 2002 Golf TDI ALH 5Speed with ~105,000Miles on it.
