Old May 21st, 2018, 06:21   #16
Franko6
You and I agree, the tensioner and chain are a life-expectancy item. Usually, the sprockets themselves, look virtually new and unworn. I haven't let any go past 400k, but quite a few went 350k without looking too bad.
I don't know why the different color for the gasser pump chain tensioner. Maybe the gasser is supposed to be 'improved'. Can't prove that by me. I seriously doubt it, but maybe the lack of tensioner let the chain slap the pump sprocket to trash, but then, the oil pump is trashed out and doesn't look right, either.
The crescent style pump is a great pump, but this one is not OEM or even close. The triangle stamped into the internal and external rotors is usually a square. The machining marks show the internal rotor is not true flat or it has worn unevenly. The outer rotor is galled. This is a junk pump from China. I wonder who sold it.
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
Old May 21st, 2018, 06:32   #17
oilhammer's Avatar
Fuel Economy: fantastic
Chinese parts strike again.
Sadly, many OEMs are sourcing stuff from that country. Just last week I tore the dash out of a 2015 NMS Passat to replace the Chinacool blend door motor, then the next day tore the fender liner out on a 2015 Taurus to replace the Chinaspray washer fluid pump.
And you should see the frightening level of ChryCo 62TE transmissions that have short internal bearing life and start screeching and howling.... guess what is stamped on those bearings? You guessed it, "MADE IN CHINA".
www.cardocautomotive.com
Old May 21st, 2018, 07:16   #18
Franko6
Try to find a company that has NOT 'sold their souls' for the price of a cheap Chinese part.
'06 Jetta wiring harnesses went bad because of Chinese 'bio-degradable' wiring insulation... great idea, eh? Same thing with BHW crank sensor wiring, just to name two Chinese wiring 'gotchas'.
1007 Olive St.
Lockwood, MO 65682
417-232-4634
Old May 23rd, 2018, 09:56   #19
Bmangdog
Regardless of the oil pump issue I am thankful I still have a block and bores that look very good. I guess you live and you learn, hopefully after frank gets done with my ALH it will go for a long long time and have a little more power
Parts have been sent and I am looking forward to doing business with Franks TDI’s. Frank has been a pleasure to talk with and is very eager to inform you on topics that other companies wouldn’t want to.
Bmangdog is offline   Reply With Quote
Old May 26th, 2018, 18:29   #20
wonneber
Originally Posted by Franko6 View Post
There is a graphite coating on the skirt side of the OEM VW pistons, as they come from the factory.
OK, I think I know what you are talking about. Is it the coating on the sides of some new pistons around the skirts?
I'm amazed the coating lasts let alone how thick it can be.
Thanks for the info.
wonneber is offline   Reply With Quote
Rod bearing troubleshooting coronan TDI Power Enhancements 23 February 8th, 2014 00:38
Rod Bearing, ALH Kurt13rager TDI 101 9 July 22nd, 2013 10:21
Why do replacement main bearing sets have 6 bearing halves with oil grooves? TB123 TDI 101 1 July 15th, 2013 10:25
Rod/Main bearing replacement opinions dieselolds VW MKV-A5 Golf/Jettas 4 November 23rd, 2012 19:07
Rod Bearing Spun BigRigger TDI 101 5 August 21st, 2006 18:15
Page generated in 0.15847 seconds with 12 queries
[Output: 71.76 Kb. compressed to 63.80 Kb. by saving 7.96 Kb. (11.09%)]
