Old August 11th, 2017, 21:33   #1
Tmorgan1988
Default Injection pump is on fire
Hello I am new to the club, I have used many threads on here to work on my recently purchased 2001 Jetta tdi! I did the 5 speed swap and it worked great, I started to drive and I felt under powered. I found another thread and changed my in tank unit (it was clogged just filthy) changed fuel filter fuel flows freely now! Injection pump still gets extremely hot to the touch! Is it burnt up by previous owner? In my vcds jetta timing my fuel temp gets up to 200 before I get scared and shut it off! What do I do? Any other causes or fixes before buying a 1000 dollar injection pump!
Tmorgan1988 is offline   Reply With Quote
Old August 11th, 2017, 21:54   #2
burn_your_money
Is your fuel filter getting this hot as well? How about the fuel return lines? If you remove the return line from the pump with the car running does fuel come out? It's a tiny little return hole and it may be clogged. I'm pretty sure there is a piston and spring in the return fitting as well. That may be seized in place limiting fuel flow. The fuel flow is suppose to cool the pump.
burn_your_money is offline   Reply With Quote
Old August 11th, 2017, 22:00   #3
Tmorgan1988
Burn your money thanks for the reply, I did fill a water bottle with diesel and put both lines in it it seems to be pushing plenty of return fuel back into the bottle I'm wondering if the clogged in tank unit from before fried my injection pump, I would add the photos but don't know how, the engine also runs fine while driving but when I pop it out of gear and let it idle down the engine shakes and it won't idle, smooth.
Old August 11th, 2017, 22:31   #4
burn_your_money
Are you able to hook the fuel lines up so that you are only using a jerry can for supply and return? Put more than enough fuel in it so you can drive it long enough to get up to 200F. You need extra fuel in the container to slow the fuel temp increase. That test will tell you if the issue is pump or fuel return/delivery related. You may just have a faulty thermo valve on the fuel pump. As a different test you could bypass it using a barb fitting for the lines and a loop of hose on both ends of the thermo valve.
Have you confirmed that the fuel temp sensor is reading correctly by taking a reading of the coolant, fuel and ambient sensors on a cold not running engine?
I know when these pumps are being calibrated on the test bench they are tested at 140*F. You're obviously a good ways over that.
Old August 11th, 2017, 22:39   #5
Tmorgan1988
No I have not done that, is it done through vcds? I would like to try that tomorrow, it is done while the engine is off?
Old August 11th, 2017, 22:46   #6
burn_your_money
The sensor test is done with VCDS with key on, engine off. All the sensors should be within a couple degrees of each other.
Old August 11th, 2017, 22:48   #7
Tmorgan1988
Ok so vcds, engine and then where do I go, I'm just starting to grasp vcds.
Old August 11th, 2017, 23:03   #8
whitedog
Measuring blocks then scroll through them until you see the temps mentioned.
Can rent movies at BlockBuster.
whitedog is offline   Reply With Quote
Old August 11th, 2017, 23:04   #9
Tmorgan1988
Ok thanks white dog
Old August 12th, 2017, 07:29   #10
KLXD
There's a thermostatic tee on the filter that recircs fuel until it warms up then sends it back to the tank.
Check that you have flow from that point back to the tank. If it's working properly drive more and worry less. The pump's sitting next to a hot engine and doing a lot of work. It gets hot.
Please start only one thread on a subject. Especially when people are responding to the first one.
Saying no to gas for 25 years:
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
KLXD is offline   Reply With Quote
Old August 13th, 2017, 02:38   #11
Tmorgan1988
Ok thanks klxd, appreciate the help, I was just worried because my neighbor has the same year Jetta and his pump stays cool after a 150 mile trip, mine gets to 200 after driving it around the block. I'll do all the recommended tests by you guys and let ya know. Thanks for the help and guidance!
Old August 13th, 2017, 06:51   #12
AndyBees
AndyBees's Avatar
Ditto what KLXD said.... Sounds like the Thermo T is malfunctioning causing the return fuel to re-circulate at the filter, thus allowing heat to build.
I'd venture to say that the IP will run a temp fairly close to the temp of the engine at full warm-up!
'84 Vanagon '02 ALH TDI engine Malone Stage 1 tune. CAT, SS 2" exhaust, E-vac system, DMF with upgrade pilot shaft, 4.57 R&P, fan assisted IC. (32 to 35+ MPGs consistently)
AndyBees is offline   Reply With Quote
Old August 13th, 2017, 07:22   #13
Tmorgan1988
Thanks Andy bees I'll check it out this evening
Old August 18th, 2017, 09:24   #14
Tmorgan1988
Thanks to everyone for the help, it was the thermostatic t in the top of the fuel filter, the car now idles like a champ and the fuel temps dropped, not allot but 20 set is something! Thanks again
Old August 18th, 2017, 09:35   #15
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Outstanding!
Fuel Temperature: 91 - 201 = 20 - 80 degrees C
That's 68 to 176 F (many of the VCDS readouts are unitless numbers).
When you get time run a can of Diesel Purge thru it, straight from the can. It could clean up the pump and injectors.
WTB: alh injection pump hub so i can mount rover 300 injection pump to it damac Private TDI Items for Sale/Wanted 0 May 29th, 2017 15:39
Jetta Caught Fire, Tiny holes in injector pump gaskets indysoto TDI 101 14 June 6th, 2014 09:43
1988 VW LT diesel fire truck firetruck fire engine TdiYardie TDI Cars for Sale/Wanted 8 October 9th, 2013 06:20
FS: 10mm Injection pump, Hard injection lines, Injectors + hardware = 400$ guillaumeber Private TDI Items for Sale/Wanted 0 September 4th, 2013 20:24
landrover mtdi injection pump, 11mm modified by Giles at performance diesel injection 79mtdi Private TDI Items for Sale/Wanted 0 July 2nd, 2013 04:25
Page generated in 0.15936 seconds with 13 queries
[Output: 118.02 Kb. compressed to 97.88 Kb. by saving 20.14 Kb. (17.06%)]
