lukewarm12
Loss of Power/No Turbo (limp mode) Please Help
My 2001 Jetta TDI lost it's turbo power which has happened to me before but last time it was the turbo actuator and when I replaced it everything was good. This time around I'm not so sure.
I had my car sitting in my driveway for about a week in fair weather conditions. The next time I drove it, I immediately noticed a loss of power that was similar to when my turbo wasn't working properly.
At first it wasn't throwing any codes, but after a few days the CEL finally came on. The codes are P0102 (Mass or Volume Air Flow A Circuit Low Input) and P1556 (Charge Pressure Negative Deviation). The first thing I did was take a part my MAF and clean it using MAF cleaner and replaced the air filter. This didn't do the trick, so I bought a new Bosch MAF off Amazon and put that in. Still nothing, so I figure my MAF is good.
Next, I went through all my vacuum lines and replaced them one by one making sure there could be no way I was loosing vacuum, but after replacing them I still had no turbo. I read around online and understood the N75 and N18 could be swapped to test if I have bad N75. I swapped the two around and still had nothing to show for it. I ended up buying a new N75 valve anyways and swapped it in but still had no luck.
I cleaned my MAP sensor, which had some oil residue on it, but this didn't work either. To be safe, I bought a new MAP sensor and replaced it but still had no luck.
To rule out that my turbo is bad, I took the vacuum line off of the EGR valve and hooked it to the lone stem on the right side of the N75 which gave me my turbo back. However, I read that this can cause over boost so I switched it back to the stock setup. I'd really like to have it work as intended.
I'm at the point where I have no idea what else it could be. I've read some articles about the brake booster having issues with losing vacuum but wouldn't I have noticed a change in the feel of braking?
