4 bolts and 2 wiring plugs 4 hours later success
removed ail filter housing
removed battery and tray
looked down thought this is going to be simple
Beetle doesn't know simple
unplugged wiring
removed 4 housing bolts
OK looks like should fall to ground
Oh no AC compressor is 1/2 in to wide for small fan to slide by
AC drier bracket in way
ok wedged small fan down past drier and compressor
still wouldn't fall down
large fan now wedged
ok removed 3 screws holding large fan to housing
whew finally housing and fans hit ground
looked at new housing and fan "Dorman 620-773" beside old housing and was a direct replacement
Been in 100 degree temp in Texas for 3 hours getting this thing out
decided to remove large fan from housing and install after housing in installed
went from bottom still had to wedge small fan around compressor thought i was going to brake one of the small fans housing arms after a few choice words and long screw driver success
installed housing and plugs
now for large fan tried bottom no go
said to myself maybe i made a mistake
well sucess lifted radiator hose on top and rotated housing until it fell in place installed 3 mounting screws finally sucess
replaced battery and air filter housings
turned key and 2 fans running
something that looks easy can be a pain in the arse
Hopefully this description will help someone who has to replace cooling fans
unplugged wiring
