sootful
I finally got around to installing a new set of injectors (new nozzles, balanced et al) into my 1.9L B4 Passat.
Injector No 1, without the hold down wiggles freely in the injector hole. A new washer, provided with the injectors was used. The hold down claw clamp was installed with a new bolt and torqued to spec (14 nm) using my digital Craftsman torque wrench. I did not tap down the injector as this is specifically listed as a do not do. The hold down, properly torqued, should be adequate. After all was hooked back up, the engine was started and it chugged. Air bubbles are visible in the clear fuel line. After trying and failing to purge the fuel line at the top of the injector, I tightened the 17mm nut to the injector back up. Being very frustrated, I hit the accelerator hard and steady for a solid minute. It was that or start throwing tools. Fuel had come up from around the base of the injector (NOT from the top). The bolt on the hold down was still torqued properly. I redid the entire procedure. Twice. Same thing.
Should I heat the ever living heck out of the washer before dropping it into the hole? Will that help the nozzle seat better? I had bought several extra washers so I can get a few more tries before I push this car off a cliff.
