Bagged wagon
Hi folks,
Just got my 2002 1.9 Tdi pd estate (on air ride )
I love the engine. Always been a petrol fan and use a Mk1 Octavia VRS with a few engine mods as my daily.
The previous owner had a very 'never really bothered me' attitude towards faults the car has developed and I just can't be like that.
I've hit a wall with the doors and windows and their behaviour. I really would appreciate some guidance please and thanks for reading this far!
Symptoms
Drivers door
Sporadically opens on fob / works fine with the key
Window willike travel a random distance before stopping and the switch needing to be pressed again
No illumination on dash warning light or interior light when the door is opened
Drivers rear
Dead
Changed the loom and the window operated fine on its own switch for 2 minutes
Tried the locks and drivers switch = nothing
Tried it's own switch and dead again
Passenger front
Works as should off fob
Window operates fine off its own switch / sporadic off the drivers switch
Dash and interior light both illuminate when the door is opened
Passenger rear
Same as passenger front in every sense except the window operation from the drivers switch is a lot worse.
Tail Gate
Operation is spot on including interior light and dash warning illumination.
I've run my vagcom on her and below are the faults that have come up.
Thanks for taking the time to read all this and I really to appreciate any guidance offered.
Cheers
Tom
VCDS-Lite Version: Release 1.2
Thursday, 13 July 2017, 20:53:34:58627
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01,02,03,08,15,16,17,19,22,29,35,36,37,39,46,47,55,56,57,75,76
Address 01: Engine Labels: 038-906-019-AXR.LBL
Controller: 038 906 019 FF
Component: 1,9l R4 EDC 0000SG 1449
Coding: 00002
Shop #: WSC 01266
VCID: 60B3C680F35B
WVWZZZ1JZ2W663500 VWZ6Z0B0009071
2 Faults Found:
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-00 - -
18080 - Coolant Fan Control 1: Open or Short to Ground
P1672 - 35-10 - - - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.LBL
Controller: 1C0 907 379 J
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 01266
VCID: 311573C4E831
2 Faults Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
003 - Mechanical Failure - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Controller: 1C0 909 605 A
Component: 27 AIRBAG VW51 01 0004
Coding: 12855
Shop #: WSC 01266
VCID: 22378C88BDD7
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
32-00 - Resistance too High
Address 17: Instruments Labels: 1J0-920-xx5-17.LBL
Controller: 1J0 920 926 C
Component: KOMBI+WEGFAHRS. RB8 V20
Coding: 01422
Shop #: WSC 00000
VCID: 2A2764A8C5E7
5 Faults Found:
01336 - Data Bus for Comfort System
37-10 - Faulty - Intermittent
49-10 - No Communications - Intermittent
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J398)
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Controller: 6N0 909 901
Coding: 00006
Shop #: WSC 01266
VCID: F09336C0A3BB
5 Faults Found:
Address 46: Central Conv. Labels: 1C0-959-799.LBL
Controller: 1C0 959 799 B
Component: 1W Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 01266
VCID: 361F40D8015F
9 Faults Found:
37-00 - Faulty
01331 - Door Control Module; Driver Side (J386)
01299 - Diagnostic Interface for Data Bus (J533)
Address 56: Radio Labels: 1J0-035-18x-56.LBL
Controller: 1J0 035 186 B
Component: Radio BNO 0004
Coding: 01401
Shop #: WSC 31414
VCID: 243B8A90A7C3
1 Fault Found:
00856 - Radio Antenna
36-00 - Open Circuit
End --------------------------------------------------------------------------------------------------
Symptoms
Drivers door
Drivers rear
Dead
Passenger front
Passenger rear
Tail Gate
Cheers
Tom
Coding: 00002
Shop #: WSC 01266
VCID: 60B3C680F35B
2 Faults Found:
P0571 - 35-00 - -
Readiness: N/A
Coding: 0001025
Shop #: WSC 01266
VCID: 311573C4E831
2 Faults Found:
Coding: 12855
Shop #: WSC 01266
VCID: 22378C88BDD7
1 Fault Found:
Coding: 01422
Shop #: WSC 00000
VCID: 2A2764A8C5E7
5 Faults Found:
Coding: 00006
Shop #: WSC 01266
VCID: F09336C0A3BB
5 Faults Found:
Coding: 00259
Shop #: WSC 01266
VCID: 361F40D8015F
9 Faults Found:
37-00 - Faulty
Coding: 01401
Shop #: WSC 31414
VCID: 243B8A90A7C3
1 Fault Found:
