Go Back   TDIClub Forums > TDI Model Specific Discussions Areas > VW Touareg TDIs
VW Touareg TDIs This is a general discussion about Touareg TDIs. Non TDI related postings will be moved or removed.
Old May 29th, 2018, 20:52   #1
FixedTouareg
TDI(s): 2015 Touareg
Default Differential oil
I want to change the differential oil, looks like I can go with the factory fluid for $27 per quart, which may be a gl-5 75w85. Ravenel makes a direct replacement that is a semi synthetic gl5 that is called MDL with limited slip. Iím contemplating just using a full synthetic gl5 75w90. What do you guys think?
FixedTouareg is offline   Reply With Quote
Old May 30th, 2018, 14:11   #2
Sprocket
Sprockette's hubby
Sprocket's Avatar
I'd go with the factory fluid.
2005 B5.5, TD Tuning, R783s, GTB2260VK, 6 speed O1E, BSM 2/09, Pod w/ 40 PSI & EGT Gauge, Thor Skid Plate, Cat FF, Euro switch
1996
B4V, 2.0L w/ BHW pistons, Rosten Rods, Girdle, 11mm, GTB1756vk, RC6, PP764s, .622 5th, Colt Cam II, Ecodes W/leveling motors & Euro switch, fog lights, Koni Yellow, Cat FF, Whitbread 2.5" DP, exhaust, FMIC
Sprocket is offline   Reply With Quote
Old May 30th, 2018, 14:27   #3
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Which differential? The front and rear use different fluid, and there are even further choices depending on which version diff it has.
My source for FRONT fluid has it available in the aftermarket, but not the rear, which tells me the rear must be something extra special.
oilhammer
www.cardocautomotive.com
Old May 30th, 2018, 18:49   #4
20IndigoBlue02
20IndigoBlue02's Avatar
Front uses a 75w90 gear oil.
G052145S2
Rear is G052196A2 for locking rear diff, no idea what it is.
On my Tiguan, instead of the factory 75w90 oil, I used Amsoil Severe Gear 75w90, in leiu of G 052145S2
2016 Tiguan SE 4Motion
20IndigoBlue02 is online now   Reply With Quote
Old May 30th, 2018, 23:49   #5
FixedTouareg
No lockers. I went to the dealer and they looked up the part numbers and came back with the same number for each, the guy was confused. They had no bottles (they take the lifetime fill very serious). I laughed. My touareg is low mileage, but all hard around town stop and go traffic.
Since then, I put 75w90 limited slip valvoline synthetic in and nothing changed. The fluid in the front was darker when I drained it, and both fluids had a good amount of the shiny break in metal. I ordered the Ravenol mdl fluid, I’m going to go 5k and drain to let the valvoline wash the rest of the break in metal out and switch to an approved fluid like ravenol.
Old May 30th, 2018, 23:52   #6
FixedTouareg
Honestly, VW just rebrands German fluids.... pentosin, ravenol, liqui moly, etc fluids and marks them up 50%. Even the vw oil filters say Mahle on them.
Old May 31st, 2018, 04:40   #7
oilhammer
oilhammer's Avatar
Yes, same as every other brand. Be thankful they are not as bad as John Deere. The JD branded screw on oil filter for my Kawasaki engine equipped lawn tractor costs $13. The Kawasaki branded filter (same filter, just different label screened on), is $9, and aftermarket non-branded ones can be as little as $5, but often of unknown quality.
oilhammer
Old May 31st, 2018, 06:11   #8
20IndigoBlue02
Since then, I put 75w90 limited slip valvoline synthetic in and nothing changed. The fluid in the front was darker when I drained it, and both fluids had a good amount of the shiny break in metal. I ordered the Ravenol mdl fluid, Iím going to go 5k and drain to let the valvoline wash the rest of the break in metal out and switch to an approved fluid like ravenol.
All the parts diagrams only mention lockers. Though, iirc, the US market 2nd gen Touareg's only had 4Motion, not 4XMotion, so it would have been a regular torsen center diff and open diffs front and rear (using EDL)
Old May 31st, 2018, 11:05   #9
compu_85
Gadget Guy
compu_85's Avatar
Ya, the T3s just have open differentials.
Pay very careful attention to the diff oil levels, moreso in the front. It's common for the front diff oil to get just a tad low, which ends up nuking the bearing on one of the output shafts. It's worth doing a top up every few services.
-J
Present:
2018 Tesla Model 3 DM. 3500 miles.
2014 Cadillac ELR. 33,000 miles.
2013 Fiat 500e. 33,000 miles.
99.5 Jetta "GLX" TDI. 323,000 miles. Power Memory Seats, HIDs 11mm pump, BV39 Turbo, RCIII 36/47 MPG.
Past:
2012 Passat SE TDI DSG. 114,000 miles. LED tails, Memory Seat, HIDs. Bought back by VW.
2004 Touareg V10 TDI. 165,000 miles. Sold to Matt98AHU w/ flat camshafts.
Thank you for giving me the BUG*PWR award. It means a lot to me!
Old May 31st, 2018, 15:52   #10
Savageman69
Savageman69's Avatar
i did all mine a few months ago used factory because i had loyalty card to use...did the tcase too...diffs were super clean...tcase not so much
2012 Highline Touareg v6 TDI - 8spd - Silver - Weathertechs - Buzzken Downpipe/Dpf/Scr Pipes - Hybrid 2260 - 4 Bar Map - JR Auto Performance/Buzzken Stage 3 Tune - 31 BFG k02s - Cayenne Trans Coding - Gutted/Painted Muffler - Full Led Swap - EGR Cooler Delete
Savageman69 is offline   Reply With Quote
Old May 31st, 2018, 22:47   #11
FixedTouareg
The only place I could find the info for he amount each differential takes was the Amsoil website. It had the fill levels in pints, but converted to quarts it was 0.8 for the front and 1.25 for the rear. I think they underfilled from the factory, because i didn’t get 2 quarts total out of both of them. My garage is slightly graded so it drains out the door, I had the car facing in for the front diff and out for the rear, to help with overfilling them a little- I read about that front bearing being starved. I hate how hard it is to find the information on fluids and fill capacities!
I am going to pick up the transfer case fluid tomorrow.
I also cycled about two quarts of pentosin chf 11s through the power steering reservoir, which was also low and not even reading on the dipstick! Did it with a turkey baster.
I’m thinking I might cycled a half a quart of brake fluid every six months too.
Honestly, I have the service plan, but last time I took it to the dealer they used the wrong oil drain plug washer (leaking) and broke the rear tab on the belly pan that locks in.... decided then I needed to take over my usual maintenance I’ve done on all my vehicles, those guys can’t be trusted. I’m a big proponent getting break in fluids out of the car.
Old June 1st, 2018, 07:00   #12
compu_85
Gadget Guy
compu_85's Avatar
Ya, VW says everything but the engine oil is "filled for life" on the Touareg
-J
Present:
Past:
Old June 1st, 2018, 09:29   #13
oilhammer
oilhammer's Avatar
Fluids are the least of the concerns, really. I would check them at least once in a while, but probably prudent to service them at least once in a while... especially the transmission.
Just did a set of tires on an '08 this morning. $1000. These are the 20" ones.
oilhammer
Old June 2nd, 2018, 10:30   #14
FixedTouareg
I hear you those tires, this one had 4/32 left at 18,500 miles. New Michelin 19”... when all said and done $1350. Most expensive car I have ever maintained.
Old June 4th, 2018, 05:57   #15
oilhammer
oilhammer's Avatar
I had a long time customer, well he still is a customer, that bought a T'reg early on, I think it was the second model year they were out. Nothing fancy, base V[R]6 model, the medium sized wheels, no air suspension nonsense, it may have been equipped with a couple minor options cannot remember. But his wife was the primary driver for it, drove mostly city, and it got some weekend highway trips as the family car. He drove a Jetta TDI every day.
Anyway, that T'reg was pretty reliable, but predictable. It needed tires and brakes, like clockwork, every 20k miles. It was not abused, it was just driven, and I personally took care of it.
So, with regular PM, it cost about $2k every 20k miles to maintain. Not including fuel, which even the 6 cyl models consume with great haste. The only thing that "broke" in 120k miles was the prop shaft (common), and the blower motor (also common). That's it. But after 120k miles, when it needed its regular feeding of brakes and tires again, in addition to its normal [not cheap] 120k PM services, the owner had had enough.
It illustrates the all-too-typical issues with ownership of one of these. And at the 120k mile mark, it is often common to see them start to need things like catalysts ($1200 part, 12.5 hour job), thermostat/housing/crack pipe reseal (another 12+ hour job), etc. Things can get REALLY expensive REALLY quickly. And then, you have to ask yourself, if you have to drop the engine out for those above items... do you also go ahead and rechain the engine, since those often are dead by 160k miles, too? I mean, you can EASILY have a T'reg that is in nice condition, well maintained, but need $10k worth of work. Which is why so many of them wind up at the auction yards for cheap.
I mean, shoot, there is a little plastic tube between the oil filter/cooler housing and the block on the V8s, and this is what you have to do to get at it:
That is on an Audi A8L, but the T'reg's 4.2L belt driven V8 (which is probably THE best engine overall in the T'regs offered here) is essentially the same.
oilhammer
Differential oil? Changing? What to use? Fortuna Wolf Fuels & Lubricants 26 September 27th, 2018 22:27
Inexpensive suction device for differential oil Turbo_Boss TDI 101 6 February 4th, 2014 13:01
Passat differential - add oil? Dustynevada TDI 101 5 February 4th, 2013 08:15
Motul 90 PA limited-slip Differential Oil 2L $26.99 Precisiontuning Ontario 0 January 15th, 2013 12:43
Is GL-5 rated gear oil ok to use in differential of auto tranny? stancho Fuels & Lubricants 3 January 9th, 2007 11:46
Page generated in 0.18850 seconds with 11 queries
[Output: 134.74 Kb. compressed to 113.13 Kb. by saving 21.62 Kb. (16.04%)]
