vworks
- Joined
- Jun 13, 2000
- Location
- Hudson, Quebec, Canada
For the past couple of weeks I have had a problem with my a/c. I works fine in the driveway (35 deg at the vents) and cruising around town. When I demand higher boost levels (on-ramps for the freeway, accelerating from lights and up hills) the system shuts the compressor off. When the engine goes back to normal load the a/c comes back on. This is especially worse when towing. I know the ecm is connected to the a/c. My max boost is around 19psi-just like most of us here. The system shuts down when the a/c pressure goes above 464psi but the fans are working fine and rad and condenser are clean. I checked the system with a Snap-On ($18,000) machine and the high and low pressures are fine and there are no leaks. The fans pull hard. The a/c is great until I go over about 15psi. Anybody have any ideas?
