Old March 11th, 2018, 16:17   #1
joemoto
Default MK6 Golf DPF compatable w/ 2015 Passat??
I recently sold my 2014 Golf back to VW after removing my DPF and was curious if I may be able to re-purpose the DPF piece of the system?
Can it even be attached to the turbo's output of the 2015 Passat?
Slight fabricating of the DPF would not be an issue if needed; I know it's a long shot but I wanted to ask before I post it for sale and buying one specifically for the 2015.
Thanks,
Joe
joemoto is offline   Reply With Quote
Old March 11th, 2018, 16:47   #2
GoFaster
Moderator at Large
No; the layout of the emission control systems on the EA288 engine (2015) is entirely different from any of the prior models.
In making this statement I am using the conventional meaning of "attached to" (only using wrenches and sockets, not cutting torches and welders), and reasonable interpretations of "slight fabricating" (not tearing the whole front end of the car apart and changing EVERYthing and having to deal with the EA288 having EVERYthing involved in its emission control systems laid out differently from what the earlier models used).
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
GoFaster is offline   Reply With Quote
Old March 12th, 2018, 05:43   #3
740GLE
Different turbo, different exhaust manifold, only use a Mk6 DPF is good for is another Mk6.
If you cut open the DPF and break out the ceramic media, then weld it back up, you got yourself a redneck DPF delete that's prob worth something to someone.
Old March 13th, 2018, 15:29   #4
joemoto
I was hoping that at least the hot side would be compatible, oh well.
Guess I'll put the delete system up for sale.
Thanks for the responses; I'll keep the stock system intact until I get another Rawtek piece.
I have a slight drone at 1200 rpm with the stock system and Malone's stage 2, is this typical?
Old March 13th, 2018, 15:48   #5
turbobrick240
turbobrick240's Avatar
1200 is not a good cruising rpm. Lugging territory. Try 1500+ rpm.
Old March 13th, 2018, 16:21   #6
joemoto
I agree, I normally activate Sport mode or manual mode with a downshift.
Old March 14th, 2018, 04:50   #7
740GLE
We don't notice any drone at 1,200 rpms. Stock exhaust at stg 2 tune.
Also 1,200 rpms is about 45-50mph in cruising back roads in 6th, she's not lugging, just plodding along. Our DSG is very willing to down shift if a hill is encountered and a bit more power is needed. Hopefully those with a 6MT down shift as well.
2012 Mk6 VW Golf TDI egr/dpf delete questions Luddite1811 TDI Power Enhancements 11 February 21st, 2017 13:48
Seat Question 2015 Passat to mk6 golf? mzg VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 0 May 30th, 2016 10:11
FS: 2011-2015 MK6, MKV, Golf, TDI, GLI, R32, Passat: UNIbrace RB & XB '12TDIJetta Private TDI Items for Sale/Wanted 2 October 19th, 2015 13:43
FS: 2009-2015 MK6, MKV,Golf,TDI, R32, Passat:DG Short Shifter,Panzer Plate-Tomball TX '12TDIJetta Private TDI Items for Sale/Wanted 2 October 19th, 2015 13:42
Golf Mk6 2.0 TDI 140 , DPF Regeneration DaleWinton VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 26 January 19th, 2015 16:52
Page generated in 0.13854 seconds with 13 queries
[Output: 79.63 Kb. compressed to 69.28 Kb. by saving 10.36 Kb. (13.01%)]
