StaceyS
Hi all,
Been considering blocking up some of the radiator on my 2011 JSW for the winter months. I washed the car the other day and spent some time on the front and saw the ambient air temperature sensor on the drivers side of the lower radiator grill.
For those of you who are blocking your grill, do you see warmer ambient air temp readings in your MFD?
If yes, anyone care to speculate on what the ECU is doing? Is there a separate Air Intake Temp sensor?
I was also thinking of blocking off just the engine radiator and leave the AC radiator and intercooler exposed. I was thinking I could accomplish this by removing the plastic valance panel behind the upper grill above the radiators and slipping a thin sheet of sheet metal (or similar) between the engine radiator and AC radiator. I'm still toying with the idea. It would be a pain to install and remove, plus, blocking the grill is probably more aerodynamic.
Its possible I may be overthinking this...
