choramix
HELLO
my car is a seat ibiza tdi
engine afn
my problem is i want to run more turbo bost but my map sensor "g71" is inside the ecu and is a sensor of 250kpa i wouls like to change them to a 3 bar map sensor this is possibel??
i have a passat 2002 tdi 130 cv sensor is a 4 wires sensor , mine inside ecu is 3 wires my idea is to put the 130 map sensor in the admision and remove the my stock sensor of the ecu e soldering the pin 1 e pin 2 of 130 sensor, but and my pin 3 in my stock sensor inside the ecu is what????
need help
anyone tried this
thank you
greatings
engine afn
need help
anyone tried this
thank you
greatings
