Finally put in my upgraded filter!
This is the install of the 5 micron Stanadyne FM 100 unit with Quick-Release filter that SUNRG started this thread with. This is the recap of my install, which is a bit different than SUNRG's.
The first step is to obtain the FM 100 head unit, filter, fittings, fuel line, hose clamps and misc. nylon ties, and plastic hose covering. I also used a Purolater Pre-Filter to pick off big stuff and to provide a visual on the fuel. This is not a mandatory part.
Then cut off the mounting flange with a hack saw (10 minute job).
Once that is done you can paint the cut area black (looks nice). Then assemble the fittings blocking off two back ports. Use thread sealing tape as required.
Side view (shows painted area):
Next is to remove the old A4 style filter. At this point, we also ran a new feed line from the lift pump delivery plumbing against the firewall (see the plastic covered hose):
A picture of the unit assembled and ready to drop into the existing round filter clamp:
Run the new fuel delivery hose, connect the existing hose from filter head outlet to the injectors,
use a 5/16" brass nipple to connect the two lengths of hose that were connected to the plastic thermostatic "tee" (return line to tank):
This is a side view of the completed assembly and installation. We filled the filter with diesel before installation. Use the lift pump to prime the system too. Check for leaks once started.
Finished, and now only very clean and highly filtered D2 enters my $600 each PD injectors. If you have any questions, please post them or PM me or SUNRG.
One thing to note is that when you go to change your filter, you do not need to disconnect any fuel lines as the filter is easily unlocked from the head and replaced with a twist. Priming can be done from the top cover removal, if you want.
Good luck!
Tony
