PG 05 GLI
I'm on a fact seeking mission.
My wife currently drives a 2013 2.0TDSG Aisin 4-motion Tiguan with 73K miles. We've been looking to replace my 04.5 GLI (190K+) with something else which means I'd get the Tiguan and she'd get a different car. It's a decent vehicle and works for what we use it for, I'd just like better mileage out of it.
Hence the question, how difficult is it to swap a TDI into a Tiguan and have it function as it came from the factory that way?
There are two engine options available (CJAA and CBEA) that are local to me. CJAA complete engine side wiring, alternator, turbocharger but does not have DPF. CBEA has turbocharger DPF, EGR intake & entire motor side harnessing ECU.
Which one would work better (ie easier swap)
Can theDSG Aisin trans computer be flashed to have TDI shift points? Will the 2.0T DSG aisin survive with a TDI? I've been looking and can't find the gear ratios for the Tiguan to compare to what a TDI has.
Intercooler plumbing - no idea on that. Have to see what the difference is in the TDI vs 2.0T
Exhaust will have to be custom built or from a place that has this car unless someone knows of a downpipe that will fit.
Will the TDI engine work with the existing fuel tank (assuming it's filled with diesel)?
How does the engine side wiring plug into the chassis? I'm not familiar with newer cars, last thing I swapped had CE2 wiring. Hard to mess up with color coded plugs that only fit one spot on the fuse block.
I live in a state with no emissions testing/inspections so I don't have to worry about that.
I'm sure there are a million other things I'm missing, just had to start somewhere asking questions.
Said car with snow tires.
Can the
