alexsmith10
I have a '96 GLX (yes I know, its not a diesel but it will be soon) that has been having a troublesome battery drain issue over the last few weeks. I have a 6 month old Optima Redtop installed that is tested good and my alternator is putting out the necessary 14.xx volts when the car is running. I even installed my spare battery from another car and it still had the draw so at this point I am convinced I am not having a battery issue but rather a wiring issue.
The draw will consistently pull about .02/.03 volts per hour from the battery, even with every fuse and relay pulled. Initially I suspected the stock radio may be at fault so I unplugged that but it did nothing to lessen the drain.
Does anyone know of any other relays or control modules that could be drawing power with all of the lower 22 fuses removed? I have a hunch that it may be the alarm control module as that caused some issues in my A3 a few years ago but I have yet to test that theory. I've heard of chaffed wires in the door boots could attribute to these issues but I have yet to see any upon inspecting the boots.
Any help would be greatly appreciated
