Go Back   TDIClub Forums > VW TDI Discussion Areas > TDI (Diesel) Emissions
TDI (Diesel) Emissions This is a discussion about emissions from TDI's. Pro's cons of Diesels (including biodiesel) effects on the environment and how they compare to Gasoline and other fuel sources for Internal combustion engines.
Closed Thread
Old April 7th, 2017, 10:20   #136
Good Ol' Boy
VeeDubTDI's Avatar
Fuel Economy: see signature
Originally Posted by tikal View Post
Thank you sir! By looking at the most holistic study we have so far in the USA the gasoline and gasoline-hybrids ICE vehicles are still environmentally more costly than modern diesel passenger cars (legally sold in the US). What will close the gap between them then?
Just adding that in the chart above, a cheating commonrail TDI would probably fall under "Diesel no SCR," not regular "Diesel."
I'd also like to see PHEVs get broken down further by energy type (California mix, NGCC and solar). Just like diesel drivers have a choice of fuel (regular diesel, biodiesel, renewable diesel), EV and PHEV drivers have energy choices.
Trusted TDI Mechanics Map || TDIClub Chat
VeeDubTDI is offline
Old April 7th, 2017, 11:59   #137
wxman
TDI(s): Other Diesel
A quick calculation using GREET, I get the following:
1.63 cents/VMT (NGCC)
1.66 cents/VMT (California)
1.63 cents/VMT (Solar Charging)
That's using the default settings in GREET except for using emissions generated in well drilling/infrastructure and electric generation infrastructure, including emission generated in manufacturing solar panels.
That's also using the European damage factors, which provide separate damage factors for rural vs urban emissions.
wxman is offline
Old April 7th, 2017, 12:04   #138
Good Ol' Boy
VeeDubTDI's Avatar
You're on top of things, Loren. I'm always impressed.
So that puts a PHEV right in line with a full EV?
Old April 7th, 2017, 12:28   #139
wxman
Thanks Lawson.
A better graphic with which to compare is this (since it also used the European damage factors rather than EPA's):
wxman is offline
Old April 7th, 2017, 13:15   #140
Good Ol' Boy
VeeDubTDI's Avatar
To what can we attribute the significant difference in EV damage costs between the two charts? Are the Euro vs EPA numbers that different?
Old April 7th, 2017, 13:28   #141
wxman
The Euro damages are separated into "urban" and "rural" damage factors. Most electric generation emissions are rural, and the damage factors are generally much lower for rural emissions than urban emissions (GREET calculates urban emissions and total emissions for each vehicle technology and fuel pathway).
The EPA damage factors are just an overall average, although direct PM and NOx emissions from the vehicles themselves are given a higher damage factor than upstream PM and NOx emissions.
wxman is offline
Old April 7th, 2017, 15:17   #142
tikal
Fuel Economy: 37 MPG (~ 45% city)
Well maybe to a certain degree for NOx but the DPF is still there so PM would be better than a corresponding gasoline vehicle, correct?
tikal is offline
Old April 8th, 2017, 14:54   #143
Good Ol' Boy
VeeDubTDI's Avatar
That depends on whether or not DPFs are linked with SCR in the GREET models.
Old April 9th, 2017, 05:43   #144
wxman
The default PM2.5 values in GREET are 0.010 grams/mile (diesel) and 0.009 grams/mile (gasoline). That includes 0.005 grams/mile PM2.5 from brake and tire wear for each.
In reality, PM2.5 from diesel with fully-functional DPF would be about an order-of-magnitude lower than gasoline. I suspect GREET takes into account the small percentage of tampered or otherwise disabled DPFs.
wxman is offline
Old April 12th, 2017, 11:41   #145
Deepwater6
Deepwater6's Avatar
Fuel Economy: average 38-40 MPG
Originally Posted by TDI2000Zim View Post
If this is correct, and he follows thru, it may be that a large number of regulations, including environmental regulations which are applicable to diesel emissions, will be rescinded by executive fiat, and perhaps, with Congressional legislation:
http://www.cnbc.com/2017/01/23/trump...aybe-more.html
I don't believe Trump has the power to shut down the EPA and change laws without a massive fight on his hands. It will be delayed for years until they can get rid of him through the impeachment process. Trump is taking us back to the 1970's and most don't like it, me included.
Deepwater6 is offline
Old April 12th, 2017, 12:43   #146
tadawson
Most? My fat hairy white butt! I'm elated with what he is doing (as are pretty much everyone I know) . . . and the EPA was created by Nixon via EO, and despite it's overreach, can die by reversal of same . . .
tadawson is offline
Old April 12th, 2017, 13:30   #147
flee
Fuel Economy: 40-ish
Yes most, as in most people did not vote for the individual.
Your understanding of how the EPA can/can't be modified is also flawed.
2002 Jetta GLS TDI wagon, 2012 Audi A3 TDI S-Line
flee is offline
Old April 12th, 2017, 17:57   #148
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
45.9% of the country voted for said person who happened to be swing states.
Rural America has a voice too and it spoke.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline
Old April 12th, 2017, 20:06   #149
flee
Thank you for a definition of a minority.
Oh yes, and don't forget that that is only the votes cast.
flee is offline
Old April 12th, 2017, 20:28   #150
whitedog
No matter who says that in bold, I just gotta laugh because birds of a feather flock together. Meaning that we usually surround ourselves with people that think like us, so it's not indicative of everyone based on what those near us think.
Just sayin'...
whitedog is online now
Closed Thread
EPA mulls over urea-injection rules TDIMeister TDI (Diesel) Emissions 26 September 8th, 2006 21:50
Supreme Court Rules on EPA Air Quality Sun Baked GL TDI (Diesel) Emissions 16 March 4th, 2001 17:40
EPA rules! Janusz Fuels & Lubricants 2 February 28th, 2001 18:45
WSJ - New EPA Rules May Fuel Profits Sun Baked GL TDI (Diesel) Emissions 5 February 6th, 2001 00:45
EPA nominee would review Clinton diesel rules Eolair TDI (Diesel) Emissions 5 January 19th, 2001 14:12
Page generated in 0.11218 seconds with 11 queries
[Output: 131.41 Kb. compressed to 110.10 Kb. by saving 21.31 Kb. (16.22%)]
