Just bought this car . Dealership did a good job covering it up. But take the belly pan off the oil pan is covered in coolant residue. Can visually see anything leaking everything is so compact. Maybe the thermostat housing?
Next oil leak. Back of moto passenger side. Noticed it at s stop light when I started to smell burning oil. Take a peak back there the entire back of motor is covered. Cannotpinpoint. It's not a valve seal. Maybe cam seal? . Turbo drain appears to be fine. But once again pretty tight back there
