lardope
This is a different twist on a familiar problem that I see a few people have posted on--the window falling into the door:
When the window was frozen it pulled out of its clips (or clamps). I took off the inner door panel and saw that nothing was broken. I tried putting the window back in the clips and tightening them, but I couldn't get the clips to tighten around the window enough to hold it. Finally, I gave up and took apart the rest of the door so everything is dissembled.
With everything dissembled, it looks like the screws are getting stuck tightening into the clips. I cleaned the screws and the clips and still no luck. I finally got the one screw to tighten all the way through the clip after much trying. The other I've given up on and don't know what to do. The one clip I can get either screw to tighten all the way into it. The other clip either screw gets stuck half-way through threading. I'm baffled why the screw is getting stuck in the clip.
I'm new to car repair... am I missing something obvious?
