2014 Passat TDI.
The car was shut down normally. Next day it would not start. Checked the codes. There are three:
5132 Valve for fuel metering N290
P 0090 00 [167]
Open circuit
5177 Fuel pressure regulator valve N276
P 2294 00 [167]
Open circuit
5179 Fuel pressure regulator valve N276
P 2295 00 [167]
Short to ground
Any ideas where I should start? What is causing this?
Thank you in advance.
P 0090 00 [167]
Open circuit
P 2294 00 [167]
Open circuit
P 2295 00 [167]
Short to ground
