Hi guys really need your help, a week ago now I'm getting a horrible shake in the steering wheel almost feels like torque steer. The wheel shakes to the right and doesn't matter the speed. It shakes the worst if I coast the car in neutral, also if I let off the gas or step on the gas for a split second. But if I'm steady with the gas it won't shake at all not matter what the speed. So far I've balanced the wheels, outer tire rod, ball joints,control arm bushings, struts and mount, dog bone and trailing arm bushings. Wheel bearing seem fine no play and no noise, axles seem good as well no play and no noise. Car only does this after driving for 30 minutes or so will not do it when cold. Also brakes are good. Any ideas guys? I'm wondering if my transmission is starting to go just at a loss.
99.5 jetta to
320,000 5spd
99.5 jetta to
320,000 5spd
