mariokordi94
Hello here I come from Croatia so I advised my colleagues to log in to this forum that here are great fans tdi i was recently bought the passat b5 1.9 tdi 66kw ahu motor but i have the next problem car in minus -1 to -10 super pale almost to tooth but it happens that at a temperature of 0 to 7.8 degrees it falls for 10 seconds if not even then it starts I think it throws gray smoke a little and when it falls in below -1 there is no smoke just the heater I was heating a snare and when it was warm the engine burns to the toe to keep quiet on the fly and does not have to wear the oil meter to drive it 170,175km / h, so I can try the temperature sensor and then some people mention that the sensor and ECU drops a small amount of fuel and when it gets a little bit more and so cast a gray smoke a little
