squire89
hey aaron, i wasn't doubting you i was more trying to get you to respond with more details....
Yeah we can use it, just send it in and we'll modify it.I still have a 5th gear reduction that I haven't used yet, any way it can still be used in this kit?
It should... the b4 uses control arms that are the same length as the MK3, but has a bit more distance between the points at which they attach. this means that if the tire at full lock does not rub the transmission when installed in a MK3 - it will definitely fit the B4.Anyone prod Aaron if the fit is fine in the b4?
? Wow ?since the pinion gear is part of the output shaft - i imagine that the kits will need to be made to match the existing r&p ratio. What r&p ratios are expected to be supported?
If you're having spreading issues, it's time for a 02m swap. The only way to keep them from spreading with very high power is to install one of these http://www.aptuning.com/index.php?p...tegory_id=697&option=com_virtuemart&Itemid=14 which makes you lose 5th gear. Fix the forks and toss a lsd in the 02m and you'd be golden.interested in this for my vr turbo. would like to see pics and info on how this mounted to existing stacks and what gears (5-6) can be used. Also curious on how the ends are tied together, i am having problems with stacks spreading apart and killing my 3rd and 4th gears
thanks
Somewhere around ~250hp and ~400tq would be my hypothesis on where you might be wiser to go to a 02m over an 02J. So basically maybe 1 or 2% of tdi's out there haha. As I said earlier, I think this is a great product for the masses. Quiafe makes a similar kit for gasser 02j's, but of course the ratios are all wrong for us.Whitbread, where do you consider the breakpoint between low hp/tq and high hp/tq to be?
Ditto! A seqential dog box would the cats meow. SQS Racing in Germany makes a setup for the 02M in TDI ratio, but it's almost $4K if I remember right .With all the guys who are into serious modifications on this site, I'm surprised I haven't seen even one sequential gearbox! 02J and 02M can both be fitted with straight-cut gears and shifted sequentially, (which is quite a lot faster).
With a tall 1st gear and closer 2-4/2-6 gear sequential setup, guys would be taking a second off their 1/4mi times.
Sorry Aaron, not trying to take away from your conversion... you have by far the most practical solution for an 02J! Sequential transmissions and straight cut gears are generally poor for a road car.
