Last Saturday morning, I got "Key not in range, no key" error and the engine shut itself off right after the ignition started. I tried 3 or 4 times, eventually it gave me an Engine error and won't crank at all.
Strange thing is, I returned to the car in about an hour and it started perfectly fine with no issues. I thought it might be just one of those rare software glitches.
This morning, it started fine again, drove to work. But when I tried to start the car again shortly after I arrived, it gave me the "Key not in range" error again.
Is it simply because the key fob is out of battery, or a software glitch? The key FOB still has its original battery, so I am guessing it could be the battery. But the key fob opens the door perfectly fine. Or could it be simply one of those rare case software glitches? As I was able to start the car with the same key an hour later. Hope I can be lucky again after work today.
I read other threads that had "key not in range" issues and none of them seemed to be conclusive. It seemed the dealer / VW were puzzled with the issues as well.
Any good insight here? The only things that happened to it recently was the TDI emission mod. I am sure there is a software update along with it as well.
Thanks.
Thanks.
