2011 JSW Died
CyberTiVo
A house
2011 JSW
2011 JSW TDI Died
I'm driving 65 mph down the highway the Glow Plug light starts flashing and the motor looses power and within a minute quits. Engine turns over but, will not start. I try to read the codes with Ross-Tech, the software sees the cable but, says not connected to the car, the green LED on the VAG cable lights. I try to read the codes with ScanTool and a OBDII cable and get similar results, sees the cable but, cannot get any data from the car. I have used both of these in the past with success. Pin 16 of the OBDII connector has 12 volts and I have a factory radio. The T94 ECU connector has 2.9 volts on CAM H (68), 2.1v CAM L (67), GND (1) is good, 12.1v on pins 87 & 92 but, pin 5 is floating (random millivolts). All fuses are good. Where does pin 5 get power? I assume the ECU has to work before I can read the codes or start the car?
What next?
740GLE
NH
Test the battery?
How slow/fast does the engine turn over?
turbobrick240
maine
A pretty large percentage of electrical problems are caused by bad ground connections.
turbobrick240
maine
You might also want to check the fuse block under the hood for indications of overheating/melting. There were some issues with some of the fuse blocks- vw was replacing the damaged ones at no charge.
CyberTiVo
A house
2011 JSW
Thanks, I will recheck my ground on the battery & the OBD connector. As I mentioned earlier, the ground on the T94 ECU connector gives me a solid reading of 12.1 volts on pins 87 & 92. I got the same reading using both the ground on the connector & the battery terminal.
When I checked each fuse in the box under the hood, no signs of overheating. Everything look crisp & clean.
I think I need to know why pin 5 of the T94 ECU connector is not getting 12v, it looks like that powers the ECU. Where does that power come from? Doesn't the ECU have to power up for me to read the codes and the car to run? If the ECU does not have power, will the car run? Are there fuses somewhere else?
turbobrick240
maine
Relay 644 powers the ecu. It's up under the dash. Are you getting 12.1V right at the battery? That's a bit on the low side if so. Wouldn't hurt to try charging the battery up some. A good battery will usually show 12.5-12.7 volts.
CyberTiVo
A house
2011 JSW
Charging the battery today while at work & I will check later when I get back. Is the relay under the panel above the pedals near the OBD connector?
turbobrick240
maine
Yes. If your car still has the original battery, the battery itself could very well be the problem. Test the voltage after cranking the engine over a bit- that will remove much of the surface charge.
CyberTiVo
A house
2011 JSW
Not sure the age of the battery, had the car 18 months. My battery charger has a battery tester on it. I will use it and turn the car over a few times to determine the battery status. Is the schematic pictured on the 644 relay? I have not found one online so, that I can test it.
CyberTiVo
A house
2011 JSW
Ok, now I'm really frickin confused. Battery appears to be good, 12.8 volts after trying to start it for 5 seconds 3 times. I removed the relay and jumped 12v (pin 1) to the output (pin 5) to bypass the relay and I still get no voltage on T94 ECU pin 5. However, I noticed that the gear indicator toggles between P and the wrench icon when the the ECU is disconnected but, when it is connected it stays on P. That makes me think it sees the ECU.
Why can't I read the codes to see why it died?
What do I do next?
turbobrick240
maine
Did you check the fuse panel at the side of the dash that you access with the driver side door open? For some inexplicable reason vw decided fuse box diagrams were unnecessary, so you should probably check them all. Other possibilities are bad wire from the relay, bad ignition switch, and there might be another relay.
jetlagmech
Toledo, WA
2010 jetta
between the battery and the cabin firewall there is a bundle of wires. several years ago I found that spot on my car, battery acid or something had pealed away the wrap on the bundle and was starting to effect the individual wire insulation. I found it before it got too far, neutralized any possible acid and re-wrapped the bundle. A possible trouble spot that is easy to eliminate.
Good luck of finding an easy fix. although sound like its too late for that already.
CyberTiVo
A house
2011 JSW
Pulled and tested each fuse, all work. There is a 645 relay with the same schematic right next to 644 going to test it. I will look inspect the wires going from the ECU thru the firewall. I found the correct ECU pinout, mine is labeled ECU17CP14.
turbobrick240
maine
The mk6 tdi's have a bosch edc17 not edc16. So there's a very good chance that isn't the right pinout diagram for your car. I think the other relay is #100 in the engine bay fuse block.
CyberTiVo
A house
2011 JSW
As I am troubleshooting the relays, I noticed when I turn on the key the pins that control the relay do not change voltage. Shouldn't one of the pins get a trigger voltage to engage the relay? Since, I don't know how much voltage they use to trigger the relays, I have just bypassed it by jumping 12v to the output. I would assume they use a 12v trigger but, am afraid to try in fear of frying the relays. Also, it seems to me that the lack of voltage change on those pins may point to another problem.
turbobrick240
maine
They aren't very expensive to replace in the unlikely event that jumping 12V did fry one. Did you check the ground connections at the chassis?
turbobrick240
maine
I think it could be a faulty ignition switch.
turbobrick240
maine
I think the dash relay may actually be marked 460 rather than 644. Let us know when you get it sorted out.
CyberTiVo
A house
2011 JSW
Picking up where I left off, I was going down the wrong road with the ECU. Found out I had the dreaded HPFP failure. I did all of the suggested replacement & cleaning but, I can't get it to run. It has started about 4 times (not all in one day) and run for about 10 seconds but, sounded really bad. Mostly won't start, tried priming air intake with starter fluid, now not starting at all, sound like it wants to. I know I am getting fuel to the injectors, loosened the supply lines and fuel squirts out when I try to start. VCDS shows the P0078 Low pressure error. All of the P0078 threads seem to deal with the CEL and the car running. What next?
PRY4SNO
Edmonton, AB
2013 Touareg Execline
Long shot but have you primed the pump/filter a few times to ensure there's not trapped air in the system?
MonsterTDI09
NoVa/NJ
2010 Jetta DSG/ up keep on 2009 Jetta DSG 2006 Jetta Pag 2 in North SEA Green
First never use starter fluid with the glo plugs on. I would check your exhaust valve. It might be stuck in the close position.
CyberTiVo
A house
2011 JSW
Yes, I primed the filter, even used some clear hose to watch the fuel flow.
I will check the exhaust valve, wouldn't VCDS detect that?
Also, forgot to mention, just trying to get it started for the buy back, only has to idle for about 3 minutes, doesn't even have to run well.
MonsterTDI09
NoVa/NJ
Did you look for storage codes. When car went into limp mode.
CyberTiVo
A house
2011 JSW
Yes, I can post those later today. Never went into limp mode, died completely. The only one now that is pertinent is P0078.
CyberTiVo
A house
2011 JSW
Sunday,04,March,2018,11:29:34:04550
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.0.2
Data version: 20150729
www.Ross-Tech.com
VIN: 3VWPL7AJ8BM708502 License Plate: ROLTRIBE
Mileage: 222210km-138074mi Repair Order:
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 56 62 72 77
VIN: 3VWPL7AJ8BM708502 Mileage: 222210km-138074miles
01-Engine -- Status: Malfunction 1010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 1010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1C-Position Sensing -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Sporadic communication error 1000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 DB HW: 03L 906 019 DA
Component: R4 2,0L EDC G000AG 9971
Revision: 12H14--- Serial number:
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 6ECADE23E097F072FD2C68D-803A
3 Faults Found:
000022 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
P0016 - 000 - Incorrect Correlation
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 222213 km
Time Indication: 0
Date: 2012.07.17
Time: 02:46:47
Freeze Frame:
RPM: 368 /min
Speed: 0.0 km/h
Voltage: 10.11 V
Temperature: 27.0°C
Idle Stabilization: 57.1°KW
RPM: 171 /min
(no units): 33.0
000135 - Fuel Rail/System Pressure
P0087 - 006 - Too Low - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 222213 km
Time Indication: 0
Date: 2012.07.17
Time: 21:09:18
Freeze Frame:
RPM: 966 /min
Inj. Quantity: 23.3 mg/str
(no units): 4.0
Pressure: 392.0 bar
Pressure: 0.0 bar
Temperature: 18.9°C
Tank Cont.: 23.2 l
P0087 - 004 - Too Low - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 222213 km
Time Indication: 0
Date: 2012.07.17
Time: 21:09:19
Freeze Frame:
RPM: 897 /min
(no units): 4.0
Pressure: 384.0 bar
Pressure: 8.0 bar
Temperature: 18.9°C
Tank Cont.: 23.2 l
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 057 A HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2705
Revision: 05351113 Serial number: 00001104020285
Coding: 0000020
VCID: 1724DBC7BF8D51BACE8AD51-8042
No fault code found.
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 114B600C49220002881006E4921B0042B70000
VCID: 7BECE777A3E599DA4AB2991-802E
6 Faults Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 177
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 05:08:03
Freeze Frame:
Count: 2
Count: 14
Count: 20480
Count: 8193
Count: 47616
Count: 62208
Count: 1022
Count: 0
01309 - Power Steering Control Module (J500)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 177
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 05:08:02
Freeze Frame:
Count: 2
Count: 14
Count: 20992
Count: 8213
Count: 48128
Count: 62208
Count: 767
Count: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 177
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.16
Time: 04:31:15
Freeze Frame:
Count: 0
Count: 14
Count: 20992
Count: 8194
Count: 43776
Count: 62208
Count: 1022
Count: 0
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 177
Mileage: 222213 km
Time Indication: 0
Date: 2012.04.04
Time: 16:27:32
Freeze Frame:
Count: 7
Count: 15
Count: 4096
Count: 128
Count: 28672
Count: 0
Count: 0
Count: 0
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 177
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 05:08:02
Freeze Frame:
Count: 2
Count: 14
Count: 16896
Count: 166
Count: 48128
Count: 62208
Count: 767
Count: 0
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 177
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.16
Time: 04:31:24
Freeze Frame:
Count: 2
Count: 14
Count: 4608
Count: 16390
Count: 44288
Count: 62208
Count: 1023
Count: 0
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 L HW: 7N0 907 426 L
Component: AC Manuell H17 0202
Revision: 00012001
Coding: 0000001002
Shop #: WSC 00066 000 00146
ASAM Dataset: EV_Climatic A01005
ROD: EV_ClimaBasis_VW36.rod
VCID: 3D68296FFD71576A3406779-8068
3 Faults Found:
13701376 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 16
Reset counter: 217
Mileage: 222213 km
Date: 2017.09.25
Time: 04:31:16
13701888 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 217
Mileage: 222213 km
Date: 2017.10.05
Time: 05:08:08
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 26
Reset counter: 217
Mileage: 222213 km
Date: 2017.09.26
Time: 23:42:14
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 G HW: 5K0 937 084 G
Component: BCM PQ35 B 011 0046
Revision: BG011001
Coding: 2F380E1A802F3EC4008800817000004441000086535D0560648020200040
VCID: 367A3643D84784B2F57C80D-8062
30 Faults Found:
00059 - Terminal 30 for Interior Lighting
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 1
Fault Frequency: 5
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.18
Time: 19:49:35
Freeze Frame:
Term 15 Off
Voltage: 12.65 V
OFF
ON
OFF
OFF
OFF
00153 - Windshield Wiper Motor; Driver Side (V216)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 177
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.25
Time: 23:58:36
Freeze Frame:
Term 15 Off
Voltage: 10.10 V
OFF
ON
OFF
OFF
OFF
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 217
Time Indication: 0
Freeze Frame:
Term 15 Off
Voltage: 14.45 V
OFF
ON
OFF
OFF
OFF
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.04
Time: 21:08:40
Freeze Frame:
Term 15 Off
Voltage: 5.85 V
OFF
OFF
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 00:12:22
Freeze Frame:
Term 15 On
Voltage: 12.65 V
ON
ON
OFF
OFF
OFF
00834 - Signal for Activation of Heated Rear Window
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 5
Fault Frequency: 8
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.18
Time: 19:49:36
Freeze Frame:
Term 15 Off
Voltage: 12.60 V
OFF
ON
OFF
OFF
OFF
00927 - Terminal 30 (Right)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 2
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 00:00:42
Freeze Frame:
Term 15 Off
Voltage: 12.75 V
OFF
ON
OFF
OFF
OFF
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 1
Fault Frequency: 3
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 00:09:01
Freeze Frame:
Term 15 On
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
00984 - Left Tail Light (M4)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 00:09:01
Freeze Frame:
Term 15 On
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
00988 - Lamp for Brake Light; Right (M10)
Freeze Frame:
Fault Priority: 1
Fault Frequency: 3
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 00:08:03
Freeze Frame:
Term 15 On
Voltage: 9.50 V
ON
ON
OFF
OFF
OFF
01299 - Diagnostic Interface for Data Bus (J533)
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 217
Time Indication: 0
Freeze Frame:
Term 15 Off
Voltage: 14.40 V
OFF
ON
OFF
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 00:12:23
Freeze Frame:
Term 15 On
Voltage: 12.50 V
ON
ON
OFF
OFF
OFF
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 00:12:21
Freeze Frame:
Term 15 On
Voltage: 12.55 V
ON
ON
OFF
OFF
OFF
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 00:12:21
Freeze Frame:
Term 15 On
Voltage: 12.55 V
ON
ON
OFF
OFF
OFF
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 00:16:09
Freeze Frame:
Term 15 On
Voltage: 12.75 V
ON
ON
OFF
OFF
OFF
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 00:12:23
Freeze Frame:
Term 15 On
Voltage: 12.50 V
ON
ON
OFF
OFF
OFF
01336 - Company Data Bus for Comfort System
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 217
Time Indication: 0
Freeze Frame:
Term 15 Off
Voltage: 14.45 V
OFF
ON
OFF
OFF
OFF
01493 - Bulb for Blinkers; Front Left (M5)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 00:20:24
Freeze Frame:
Term 15 On
Voltage: 12.70 V
ON
ON
OFF
OFF
OFF
01495 - Bulb for High-Beams; Left (M30)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 00:20:24
Freeze Frame:
Term 15 On
Voltage: 12.70 V
ON
ON
OFF
OFF
OFF
01505 - Bulb for Blinkers; Rear Right (M8)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 00:08:58
Freeze Frame:
Term 15 On
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
01516 - Terminal 30; Left
Freeze Frame:
Fault Priority: 1
Fault Frequency: 6
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.25
Time: 23:58:35
Freeze Frame:
Term 15 Off
Voltage: 10.10 V
OFF
ON
OFF
OFF
OFF
01518 - Bulb for Back-Up Lights; Left (M16)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 00:08:58
Freeze Frame:
Term 15 On
Voltage: 12.40 V
ON
ON
OFF
OFF
OFF
01800 - Light Switch (E1)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.17
Time: 23:30:38
Freeze Frame:
Term 15 Off
Voltage: 12.95 V
OFF
OFF
OFF
OFF
OFF
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.17
Time: 23:42:10
Freeze Frame:
Term 15 On
Voltage: 12.55 V
ON
ON
OFF
OFF
OFF
02391 - Terminal 30 Reference
Freeze Frame:
Fault Priority: 4
Fault Frequency: 4
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.25
Time: 23:58:35
Freeze Frame:
Term 15 Off
Voltage: 10.10 V
OFF
ON
OFF
OFF
OFF
02395 - Parking Light Front Right (M3)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 00:20:26
Freeze Frame:
Term 15 On
Voltage: 12.75 V
ON
ON
OFF
OFF
OFF
02745 - Bulb for Daytime Running Light; Left
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 00:20:22
Freeze Frame:
Term 15 On
Voltage: 12.75 V
ON
ON
OFF
OFF
OFF
03266 - Control Circuit for Signal Horn
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.18
Time: 19:49:36
Freeze Frame:
Term 15 Off
Voltage: 12.60 V
OFF
ON
OFF
OFF
OFF
03384 - Windshield Washer Jet Heating
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 00:20:22
Freeze Frame:
Term 15 On
Voltage: 12.75 V
ON
ON
OFF
OFF
OFF
03396 - Supply voltage terminal 30 for central locking
Freeze Frame:
Fault Priority: 1
Fault Frequency: 4
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.18
Time: 19:49:36
Freeze Frame:
Term 15 Off
Voltage: 12.60 V
OFF
ON
OFF
OFF
OFF
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R0250DN
Coding: 00003044
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360_SE36.rod
VCID: 39603D7FE9596B4A185EA39-806C
Seat occupied recognition:
Subsystem 1 - Part No SW: 1KM 959 339 HW: 1KM 959 339
Component: BF-Gewichtss. 007 0001
Serial number: ---0000R--0005LMDT00
Crash sensor for side airbag; driver side:
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME125A425EZZZ-
Crash sensor for side airbag; front passenger side:
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME7828265DZZZ2
Crash sensor for side airbag; rear; driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME6A1F5426ZZZU
Crash sensor for side airbag; rear; passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME4C6C6C26ZZZ%
Crash sensor for front airbag; driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME4D137526ZZZH
Crash sensor for front airbag; front passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME12147526ZZZ5
4 Faults Found:
12583424 - Powertrain Databus
U0002 00 [008] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 217
12670208 - No Communication with Instrument Cluster
U0155 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 3
Reset counter: 217
13635840 - Supply voltage
U1011 00 [008] - Voltage too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 217
9483264 - Seat Occupied Recognition
B10B4 00 [008] - Function Restriction due to Undervoltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 8
Reset counter: 217
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422KDC0008C
Coding: 188A140000
Shop #: WSC 00066 000 00184
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 76FAF64398C7C43235FCC0D-8022
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H07 0013
Serial number: 0224833
Coding: 820000
4 Faults Found:
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 217
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
136194 - Supply voltage
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 217
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
147464 - Terminal 15
B1148 29 [008] - Signal Implausible
Freeze Frame:
Fault Priority: 6
Fault Frequency: 5
Reset counter: 217
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
617736 - Selector Lever Park Position Lock Switch
B1162 29 [009] - Signal Implausible
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 217
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K0 920 971 C HW: 5K0 920 971 C
Component: KOMBI H23 0204
Revision: X0023007 Serial number:
Coding: 270F01
ASAM Dataset: EV_KombiUDSMM9RM10 A04203
ROD: EV_KombiUDSMM9RM10_VW36.rod
VCID: 2F740327271DB5FAB6BADD1-807A
4 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 217
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
13893632 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 217
Mileage: 0 km
Date: 2000.00.00
Time: 00:00:00
12648448 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Reset counter: 217
Mileage: 222213 km
Date: 2017.09.25
Time: 04:31:15
13631488 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 208
Mileage: 221808 km
Date: 2017.09.09
Time: 12:15:09
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 C HW: 1K0 907 951
Component: J533 Gateway H37 0614
Revision: H37 Serial number: 12051101210530
Coding: 352002
VCID: 3076005B3A23AA82AF80C65-8064
5 Faults Found:
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 9
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.16
Time: 04:31:14
00381 - Databus Instrument Cluster
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
00457 - Control Module for Network (J519)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.25
Time: 23:42:12
01330 - Central Control Module for Central Convenience (J393)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.25
Time: 23:42:12
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.26
Time: 00:16:07
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 001 0001
Revision: 00001000 Serial number: 1225223RCMM006
Coding: 0000002
VCID: 7EEAEE63B0F780F26D8CB8D-802A
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.25
Time: 23:57:33
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 920 971 C
Component: IMMO H23 0204
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_ImmoUDSMM9RM10 A01200
ROD: EV_ImmoUDSMM9RM10_SE25.rod
VCID: 6AC2D233DC7F10D2A14444D-803E
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0002274425
Coding: 0004B5
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 5BAC87F70325795A2AF2391-800E
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005695060
Coding: 000490
3 Faults Found:
68098 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 217
Mileage: 222213 km
Date: 2017.10.04
Time: 23:42:12
68100 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 217
Mileage: 222213 km
Date: 2017.10.04
Time: 23:42:12
68107 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 217
Mileage: 222213 km
Date: 2017.10.05
Time: 00:12:20
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
VCID: 347E0C4BCE3B9AA2CB68EA5-8060
4 Faults Found:
00750 - Warning Lamp
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Reset counter: 40
Mileage: 222213 km
Time Indication: 0
Date: 2012.06.27
Time: 01:34:31
Freeze Frame:
Voltage: 8.75 V
PD
Temperature: 14.0°C
RPM: 245 /min
Speed: 50.0 km/h
Speed: 50.0 km/h
Count: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.27
Time: 21:45:11
Freeze Frame:
Voltage: 12.38 V
DU
Temperature: 32.0°C
RPM: 1498 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.27
Time: 21:38:51
Freeze Frame:
Voltage: 12.38 V
DU
Temperature: 33.0°C
RPM: 1498 /min
Speed: 0.0 km/h
Speed: 0.0 km/h
Count: 0
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Battery Volts: 12.7 V
PD
Temperature: 30.0°C
Count: 2
Steering Angle: 0.00°
Count: 0
SteerAng n.Init
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0002332714
Coding: 0004B4
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 5CAE84EB062B7E6223F8225-8008
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000005679652
Coding: 000490
3 Faults Found:
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 217
Mileage: 222213 km
Date: 2017.10.04
Time: 23:42:12
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 217
Mileage: 222213 km
Date: 2017.10.04
Time: 23:42:12
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 217
Mileage: 222213 km
Date: 2017.10.05
Time: 00:12:20
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
Component: Radio Prem-8 H16 0044
Revision: -----28S Serial number: VWZ4Z7L3167756
Coding: 0500040004
VCID: 61D0A3672149530A70AEFB9-8034
3 Faults Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 177
Mileage: 192622 km
Time Indication: 0
Date: 2017.01.30
Time: 13:00:18
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.04
Time: 21:07:40
00849 - S-contact at Ignition/Starter Switch (D)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 217
Mileage: 222213 km
Time Indication: 0
Date: 2012.02.25
Time: 23:57:29
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 HW: 5K0 035 730
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007669670655
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01009
ROD: UHVNA.rod
VCID: 62D2BA13244F489269B4ECD-8036
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 217
Mileage: 222213 km
Date: 2017.09.13
Time: 21:14:12
U1400 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 217
Mileage: 222213 km
Date: 2017.09.13
Time: 21:14:12
End-------------------------(Elapsed Time: 02:59)--------------------------
