Dustynevada
Help! I recently replaced the driver side output shaft seal and o-ring on the differential. All went well until I needed to add the 90 wt gear lube. There is only (as far as I can find) one fill/check plug that is on the passenger side.
Does this fill for the entire diff? Not the autotrans but the diff? The diff is completely drained I cannot get it to accept any oil. As if it is full. Maybe the gear lube is too cold to drain into the diff?
Any help would be appreciated as I am at a loss.
Thanks!
Thanks!
