bigred177
Earlier this year, my clutch would not stay disengaged. Both the master and slave cylinder were old so I replaced them both. They've been good for 4-6 months and 5k miles or so. A few weeks ago I drove the car from Houston to Austin, no problems. Pulling out of the driveway the very next morning the car wouldn't go in gear; the clutch wasn't disengaging. After some poking around I found the plastic nipple on the feed line from the brake fluid res. was broken on the master cylinder.
R&R a new master cylinder and now the car is being very strange. Sometimes the clutch still won't disengage, sometimes it will, but there isn't any rhyme or reason to it. I bled it using the two people pump method first. After it was acting funny there I vacuum bled it. No bubbles were coming out. Then, just to make sure, I had someone pump it up and cracked the bleed screw. The stream was solid, no bubbles at all.
When the car is off, everything feels fine. I can start the car with it in first/sometimes neutral and use the clutch like normal, briefly. Once it decides it's done, I can't get it into any gear and no amount of pumping on the clutch will get it to disengage. I have to turn the car off and restart it a differing number of times each time before the clutch will "let go" and be usable again. Then it will restart the process of being usable for an unknown number of times and then quit again.
The car was great before the new new MC swap. Clutch engagement is solid and no slipping. Before I swapped both clutch pieces I had not had a problem in 60k miles.
Did I get a bad MC out of the box? Is something wrong with the slave? Did the clutch decide to eat it at the same time as that plastic nipple?
