Old October 9th, 2018, 05:46   #211
jhax
Thank you, I appreciate the comment. I was suspecting an oil galley, that is promising. Which pressure sender are you going with? Obtaining the oil feed and drain lines have been a battle. Turns out the first feed line I got was an -AN 5, I asked a local shop to make is shorter for me, he ended up cutting the line, and not being able to find the correct part and ended up making me a new one. I have been told my the local hydraulic shop that they could braise new stainless steel braided line onto my old solid steel drain line that came with the turbo, but after looking at Michael's (digital corpus) issues with his frankendrain line, I think I will just have them build me one with the proper ends. I have the car scheduled to get painted in a few months, however, I am hesitant with getting the body pained first. I NEED to get the undercarriage needle scaled and redone and I would like to get the engine bay painted first, just because it makes sense. I can drop the motor into the fresh bay and save up for body painting down the road. I have the needle scaler, just not the rotisserie to flip the car on its side nor the air tank that will handle the scaler. So I need to see if I can call around or look on CL or something.
jhax is offline   Reply With Quote
Old October 9th, 2018, 18:26   #212
ToddA1
Fuel Economy: Dismal
Needle scaler....? You’ll be there for days. Those are good for the tight areas, traditional tools can’t get in.
Go to Harbor Freight and buy a few of the 4.5” angle grinders for $10 per. Buy some 4.5” knotted wheels and some stringer wheels. These will burn through the undercoating.
Use your needle scaler, if there’s stuff the above can’t get.
You can build a tipsorie, for about $100, or a rotisserie, for about $200. Not really sure what you’re looking to achieve.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is offline   Reply With Quote
Old October 10th, 2018, 09:41   #213
jhax
Interesting, I have not heard of a tipsorie, I cant seem to find one online. Is that a misspell? I may be able to pull it off with the space I have. When you say 4.5” angle grinders for $10 per, do you mean sanding disks?
Thanks!
Old October 10th, 2018, 13:28   #214
ToddA1
A grinder is an electric power tool. $10 is a sale price, but sales happen all the time.
https://m.youtube.com/watch?v=70ggHl6GGZA
-Todd
'97 B4: Stock
Rabbit build
Old October 11th, 2018, 05:35   #215
jhax
Todd, thanks for the clarification. I got hung up on the $10 grinder, since it's the disks that typically cost $10, I have a dewalt angle grinder already. I actually do have plans on paper for a wood rotisserie, although that is a viable option, I don't know if I would have the space in my garage as I share a two car garage with the neighbor on the other side of the duplex. I see now, a tipsorie allows you to tip the car while it's on the ground, as opposed to a rotisserie, where the car is already in the air. Thank you for the clarification.
These are the plans I originally found...
http://www.vwcaddy.com/showthread.ph...tisserie-plans
This one seems a bit more compact:
https://forums.vwvortex.com/showthre...1#post52622006
https://forums.vwvortex.com/showthre...1#post52849640
Old October 12th, 2018, 11:41   #216
ToddA1
I had 3 name brand grinders and I got tired of swapping different wheels, brushes, etc. buying more grinders and having them all plugged into a single power striip, sped up the work. Way more convenient.
I use the $10 grinders all the time. For the metal work I do, they’re perfect. I also stopped buying the name brand consumables. I can’t really tell a huge difference, for the huge price difference.
-Todd
'97 B4: Stock
Rabbit build
Old October 12th, 2018, 17:33   #217
jhax
Thank you for the help. Luckily I got mine for no money, borrowing it until I don't need it anymore. But I will definitely look into it. On another note, after much trial and tribulation, I finally sourced my turbo oil feed and drain lines!
Fully built alh tdi. Est 265 whp Bdpprocessors Private TDI Items for Sale/Wanted 28 March 31st, 2017 13:59
WTB: mk2 blinker switch with cruise, hazard switch, mk2 golf wiper stalk burpod Private TDI Items for Sale/Wanted 2 February 27th, 2012 06:28
fully built alh tdi for sale Bdpprocessors Private TDI Items for Sale/Wanted 31 August 26th, 2011 16:52
FS; 90 MK2 Turbo Diesel built nicely, UTAH zuks90idi TDI Cars for Sale/Wanted 0 July 15th, 2010 11:49
Mk2 Tdi Alh X@V TDI Conversions 23 September 1st, 2008 08:56
Page generated in 0.13592 seconds with 12 queries
[Output: 83.08 Kb. compressed to 72.62 Kb. by saving 10.46 Kb. (12.59%)]
