jrip
I have a 2002 Jetta TDI, and today I had the check engine light come on. So I came back to the house and hooked up my Vag-Com to see what codes are showing. P0102 is the only code showing. So I opened up the air filter box and the filter looked real dirty, so I replaced it. I also replaced all the 5MM vacuum lines I found. They looked pretty sad from the outside, but none seemed to be leaking. The MAF did not seem to be dirty, but without truly disassembling it I can't be sure. I cleared the code, and it came back immediately. It seems to start and run just fine. I took it out for a short run to check acceleration etc and it ran great. I'm at a loss. I know there are some other smaller vacuum lines that I did not replace because I don't have the right size vacuum line although they seemed to be fine. I have several questions. 1. What size are the smaller vacuum lines. 2. What size are the torx(safety) screws that fasten the actual MAF sensor to the housing? I have 15, 20, 25, 27, 30, and a couple more both larger and smaller sizes, but none of them seem to fit. My MAF is an original Bosch.
