Work has been progressing slowly on the old gal due to other commitments and the rain we have had. But, I have adjusted the valves, replaced the leaking valve cover gaskets, and made an inspection of various things that have resulted in a new list of items to address. Seems like the person the restored (using the term loosely) the Bug only went about 1/2 the way on each item he touched. I don't know if he was not skilled or just accepted a half-ass fix for all the things he worked on.
To put it in perspective, the wiring is a mess (in general), the seats were rebuilt without the use of the correct formed horsehair pads (he used foam rubber) making them anything but firm like they should be, using a cheap cable pull to open the bonnet rather than using the EXISTING assembly in the glove box and getting the correct cable, etc, etc.
What the above means is that to get this gal road worthy and to correct the half-assed fixes that are currently incorporated into the car will take me twice as long as I had anticipated. No big deal, but I don't like unwinding repairs to have to rewind them correctly, especially since someone already put a lot of work into this car.
The latest projetcs are (some completed):
Re-cable the battery:
Add a "hot start relay" to remove the high amperage load in the Chinese ignition switch during starting;
Install a new Bosch solid state voltage regulator in place of the electro-mechanical unit (which was fried):
Rebuild the windscreen fan blower assembly (currently started):
Next project will be removing the new covers off the seats and installing the correct pads.
