Moesauction!
Vendor , w/Business number
- Joined
- Apr 2, 2008
- Location
- kansas city
- TDI
- 2001 tdi 423,000 sold:[ , 2003 tdi 425,000 lower ryder hot rod 17/22 520rc southbend clutch. 2005 mercedes cdi 232,000 sold , 2003 7.3 ford 586,000 miles.
only ahs 40,000 miles on it just removed from car and went to a 17/22 setup. Tight no play as a new one would be.
was bought from id parts about 1.5 years ago.
All is tight and as it should be text me at 918633-0838 ill send you pictures.
Garrett VNT-17 Turbocharger (A4 ALH) also VNT-17 Outlet Adapter for 50.00 perferr to sell together for 400.00 plus 25.00 for ship.
best to text me at 918-633-0838 for pictures ect.
Garrett
OEM Part Number: GT1749VB
Manufacturer Number: 7210215006
Factory fresh VNT-17 turbos from Garrett. These are the OEM turbo on the European 150hp 1.9L TDI equipped Volkswagens. The VNT-17 is an upgrade from the original VNT-15 turbo allowing you to run higher boost levels and, many believe, providing superior durability.
The VNT-17 bolts directly up to the ALH and uses the same oil feed and return lines, but it requires either an adapter or the clip-connector pipe for the compressor output to match up with the stock ALH intercooler pipes.
If you happen to have a 99.5 ALH engine you will also need to purchase the later style pancake pipe in addition to the clip connector hose.
Price includes installation hardware (gaskets, washers, nuts). This is BRAND NEW turbocharger and there is no core charge required on this turbo.
AARODRIGUEZ CORP
This all aluminum adapter fits inside the outlet of a VNT-17 so that a standard hose with clamp can be used, rather than the ~$200 VNT-17 clip-connector hose.
This adapter was specifically designed for ALH owners who want to do a VNT-17 upgrade. With this adapter the stock ALH turbocharger outlet hose can be used.
Please Note: in order to use this adapter you must clock/rotate the compressor housing on the VNT-17 as well as modify (cut) your stock ALH hose.
Garrett
AARODRIGUEZ CORP
