got error terminal 30, wont start, also getting 01314 error
friend has a 2007 Octavia that has a repeatable fault with starting.
if the ignition is left on or its a hot day/car hot, when the keys is turned the engine just spins. if the ignition is left off for a few minutes it will generally start.
when using my vcds cable, during the non start period I cant get any coms from the engine ecu.
I wonder if it is the 109 relay prob. but we cant find it. looked under the drivers foot well but cant see a relay with that number.
the 2 errors we get are:
005633 - Relay for Supply Voltage Terminal 30 (J317) on the engine ecu.
and
01314 - Engine Control Module on almost all the other ecu's.
new battery was fitted and still doing it.
its like something is overheating?
when it will start the engine light comes on and esp comes on briefly, after starting engine the engine light goes out.
when it wont start the esp light stays lit and there is no engine light.
and
