Old July 9th, 2018, 19:31   #1
ajoncar
Default I want a mk7 alltrack with a diesel
What do you guys think would be the way to go?
Buy an all track and swap in a diesel?
or buy a 15 diesel and swap in the awd?
It needs to be a manual, so im thinking that id need to get the alltrack as the good car since it will have the awd transmisson, altough the gearing ratios will be incorrect for the tdi. I would then look for a wrecked tdi for the motor/wiring'cpu but the ratios would still be wrong.
I was also thinking that i might be able to get a euro mk7 manual 4motion tranny imported from korwerks or the like that would already be geared for a tdi. im going to look into that option as i think it would be the best.
Any thoughts? Does anyone foresee more complications that the ones i have addressed? Thanks in advance for your input.
ajoncar is offline   Reply With Quote
Old July 9th, 2018, 20:27   #2
The Tortoise
You'd have to delete this emissions stuff for sure.
But really, for the cost and hassle you're better off just tuning a regular Alltrack. It'll be quicker than a TDI and there's no way you'll make your money back on fuel savings.
Sent from my XT1635-02 using Tapatalk
The Tortoise is offline   Reply With Quote
Old July 9th, 2018, 20:48   #3
For less money and much less hassle you could buy a BMW 328d Wagon. Only thing you can't get is a manual transmission.
Old July 10th, 2018, 03:12   #4
marcusku
Fuel Economy: 56/52/48
Before they sold off the 15's sitting in dealerships I was contemplating swapping in a Euro 1.6L into a regular gas sportwagen. It's not an impossible task but also not easy or cheap. To ensure I had all the parts and wiring I was going in import a whole wrecked donor car from Europe but this has it's complications. You'd have to find someone to ship it over in pieces. Mk7's have a lot of control modules that are component protected. Unless you are really good with programming and wiring, you'll want the whole donor car to switch over the necessary electronics, immobilizer etc. I was looking at $8-10k for get the donor car. To help bring down the cost of the project I had planned on finding a reasonable wrecked US sportwagen to convert. Would be a cool project, just would require a lot of time and money!
15' Golf Sportwagen SEL 6 speed manual, red
02' Golf GLS 6-speed, white, sold at 308k
marcusku is online now   Reply With Quote
Old July 10th, 2018, 05:13   #5
740GLE
An Alltrack owner tried to transplant a GTI 2.0T into his Alltrack, he ran into major issues with the ECU reprogramming to accept the BCMs.
I'm not sure he was working with the best tuners/coders, but I believe each BCM is coded for the original 1.8T VIN and couldn't play nice with the 2.0T ECU, he had to use the 2.0T due to the VVT of the GTI.
My best guess is you would need to almost import a whole front clip from euro land including ECU 6MT and possibly the rear diff.
I've heard the independent rear subframe of the R (same as the Alltrack) can't be swapped into the NAR due to slight differences in the NAR TDI.
If I had more money than brains and a second car, I'd be willing to pay some shop to try it.
Getting 27-29MPG isn't fun at all
Old July 10th, 2018, 06:36   #6
Discovery
Exactly
Discovery is offline   Reply With Quote
Old July 10th, 2018, 07:27   #7
Garrison
TDI(s): 2006
I can't even imagine the repair-cost nightmare that thing would be.
Garrison is offline   Reply With Quote
Old July 10th, 2018, 09:53   #8
740GLE
Prob no worse than any TDI offered over the past 9 years. I know 335d had EGR clogging issues and similar HPFP issues, but its not like VW's are "cheap" to maintain to start from.
Old July 10th, 2018, 10:03   #9
You think repair costs on a frankencar that no one has ever seen before would be less expensive? I don't. It won't have any warranty. At least you can buy an extended service plan for the BMW.
Old July 10th, 2018, 17:44   #10
mxtdiguy
I want one too, but a settling for just a "prerunner" version or as they call it here in Mexico a "Crossgolf" . Lifted, but 2wd.
mxtdiguy is offline   Reply With Quote
Old July 10th, 2018, 19:40   #11
Mrrogers1
Fuel Economy: Never high enough but always trying for more.... (See signature)
335D for sure
Mrrogers1 is offline   Reply With Quote
Old July 11th, 2018, 15:42   #12
GreenLantern_TDI
GreenLantern_TDI's Avatar
Fuel Economy: Mid 40s
I saw the new Golf R in the show room. Loaded... $42,000. Its all a guy could want minus the diesel but as others have said itll be faster than the TDI anyway. Its got warranty and payment options. If i wasnt blowin truckers at the flyin J to make ends meet as it is Id love a Golf R.
2015 Golf SEL. Frost Heater. Ares Skid Plate. Fumoto Valve. PentoIII.
GreenLantern_TDI is offline   Reply With Quote
Old July 11th, 2018, 16:49   #13
UFO
UFO's Avatar
TDI(s): 2001 Beetle
Fuel Economy: 50mpg on B100
TMI, GreenLantern.
2001 Beetle - EGR delete, 01M-ectomy, Atlas skidplate, vented, Frostheater.
I'm not coasting, I'm shifting slowly.
UFO is offline   Reply With Quote
Old July 11th, 2018, 20:18   #14
turbobrick240
turbobrick240's Avatar
Too much money and headaches, imo. It would be a hella cool swap though.
turbobrick240 is online now   Reply With Quote
Old July 12th, 2018, 05:28   #15
740GLE
You can thank the fan boi racers for keeping the R still on the market, who knew dealers could move 40-43K Golfs, some of them even trying to charge 5-10K "market adjustments".
Now they just need to bring the R estate for those that actually want to use their car for useful things like going from 0-60 with 15 bags of mulch.
Success! - ALLTRACK Springs on Mk7 Sportwagen TDI = 2" Lift! cevans VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 72 November 12th, 2018 20:21
Mk7 Golf gas or diesel, please help me decide JerseyMike VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 46 April 24th, 2018 13:43
How do you put additive or fill diesel, if you need with a jug or can? MK7 Cutandthrust VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 5 October 3rd, 2015 19:19
Page generated in 0.20887 seconds with 13 queries
[Output: 126.48 Kb. compressed to 105.40 Kb. by saving 21.09 Kb. (16.67%)]
